VideoHelp.com Forum
  1. Member seven1970's Avatar
    Does anyone know how to increase the volume on an AVI file?
    Some of my ripped dvds are low volume and I would like to "louden" them up a bit.
    cheers.
    Depends on the type of audio as to how simple it is. For MP3 audio you can do it in virtualdub. Load the file, click on Audio->Full Processing, then click on Audio->Volume. adjusting it up by +6Db should double the current level. Just remember to set your compression type to MP3 and configure it before saving out the new video.
    Or you could use virtualdubmod, demux the audio to an mp3 file, use mp3gain to change the audio without re-encoding it, then mux it back into the video again in place of the original.
    I don't know of a simple way to do this for AC3 audio.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  3. Member seven1970's Avatar
    Cheers
    use mp3 gain now to level out my iriver
    works well
    I used to have the same problem. Now I just use VirtualDubMod, as follows:
    1. Open file to be modified.
    2. Set Compression Speed of choice (I usually use Direct Stream Copy, for speed).
    3. Click on Streams > Stream List
    4. Right Click on the Speaker Icon - Top Left (You will notice at this point that the 'Volume' option is Greyed out).
    5. Select Full Processing Mode (not to be confused with the one in stage 2)
    6. Once again, select Streams > Stream List - The 'Volume' option is now available to select, so select it.
    7. Check the Adjust Volume... box & adjust the slider to the Percentage volume Increase or Decrease you require.
    8. OK the window.
    9. Save your new *.AVI file with boosted volume.
  1. Increase VOB file volume
    By boren1969 in forum Newbie / General discussions
    Last Post: 5th Dec 2010, 22:19
  2. how to increase volume of a mkv file
    By wolvie77 in forum Audio
    Last Post: 8th Nov 2010, 14:54
  3. volume increase
    By natty in forum Newbie / General discussions
    Last Post: 18th Jan 2008, 10:08
  4. Increase Audio Volume?
    By ambrosechapel in forum ffmpegX general discussion
    Last Post: 7th Nov 2007, 08:05
  5. Trying to find a program I once had to increase volume on a audio file
    Last Post: 18th Jul 2007, 14:57
