VideoHelp.com Forum
Results 1 to 18 of 18
    hi i have avi video file with true 5.1 ac3 sound i want burn it on dvd (in standard dvd video format)
    so i can watch it on my dvd player and home theater with keeping audio as original how can i done it?please help
    (this video file contains six different channel sound tracks i have checked it on nero)
    i fear if i directly burn on dvd with nero dvd video plugin i could lost its 5.1 feature
  2. Hello Ladies stiltman's Avatar
    Originally Posted by jagabo
    Originally Posted by stiltman
    http://www.videohelp.com/guides?searchtext=&tools=&madeby=&formatconversion select=AVI+to+DVD
    thanks i have download some useful guides (i.e. avi with ac3 to dvd with ac3)
    but it doesn't explain any about different channel audio sources there is only one audio track with ac3
    is there any guide for authoring true 5.1 dvd video? please i am newbei in this area
    If your AVI file already has 5.1 audio then try DVD Flick or ConvertXtoDVD. These will create a valid DVD structure and keep the AC3 audio if it is compliant.
    If the audio is 5.1 then there really isn't a lot you can do. It is possible to create a fake 5.1 from a stereo track, but the results are far from true 5.1, and often inferior to what a good Dolby Pro Logic II amplifier can do.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    thanks a lot!
    so i just have to drag and drop with software u suggested
    to author real 5.1 dolby digital dvd?
    my video file contains
    Video: DivX 5 616x336 25.00fps 829Kbps [Video 0]
    Audio: Dolby AC3 48000Hz 6ch 192Kbps [Audio 1]
    i gonna play this dvd on my dvd player having dolby pro logic 2 (dolby digital/ dts) surround
    will it fine with dvd
  6. Member MysticE's Avatar
    With Nero if you have Smart Encoding ticked at the last step it will tell you if it's gonna re-encode. Video and Audio Smart Encoding percentages will be listed. But your 'AC3 48000Hz 6ch 192Kbps' might trigger a re-encode as Nero uses 192Kbps for 2ch and 448Kbps for 5.1. You could also set Nero's audio manually to 5.1.
    6 channels in 192kbps ? errwww. That has got to sound rough as houses. Are you sure it isn't AAC @ 192 kbps ?
    yes its ac3 not aac
    do i need re encode the audio or not to maintain its 5.1 feature? yes then how
  9. Originally Posted by namesake
    Too late for that. It's already wrecked. You may as well use it as-is.
  10. Banned
    Have you also checked it on your speaker system
    Nero 6 and higher are not a reliable source of information.
    well not on my pc speaker system.(2.1) my home theater system is connected to my dvd player and its fixed
    so that why i want to take it on dvd disk?
    is there any software who give me complete information about video audio properties? (reliable)
  12. Member ricardouk's Avatar
    You can check the properties with MediaInfo, for an avi to dvd program tha doesnt reencode ac3 i recommend avs2dvd
    I love it when a plan comes together!
    Ricardo Santos
    thanks! information is same as above just bitrate problem. its 192 kbps instead of 448 kbps
    isnt there any way to reencode bitrate of audio?
    if i burn with same 192 kbps bitrate what will happen?
    waiting ur answer
  14. Member AlanHK's Avatar
    waiting ur answer
    There's nothing technically wrong with 192, it should work. Reencoding 192 to 448 will just give you a bigger file, with no improvement in quality. (Like enlarging a grainy image: it doesn't get smoother.) You'd need to start with the original audio if you want to do that, not your 192 version.
    hi
    as stated earlier conversion with convertxtodvd or dvdflick is easiest option to create dvds.
    i did that till i bought dvd player that handles divx.
    now they play with full 5.1 and if the avi is not compatible with your divx player i reencode with virtualdubmod to divx
    so u can create dvds with 5.1 or simply play avis with 5.1 as divx (often xvids play on my player)
    saves time if u dont need a dvd
    doorman
    thanks i'll go with same bitrate. i play file on pc on 2.1 and it gave me marvelous performance on audio it was very clear and loud
    i just want to know is it possible to upscale the bitrate?
    if yes then how?
  18. Member AlanHK's Avatar
    if yes then how?
    It's a waste of time and can only degrade the audio.
  1. Replies: 4
    Last Post: 31st Oct 2011, 14:07
  2. Replies: 0
    Last Post: 22nd May 2010, 18:44
  3. Replies: 4
    Last Post: 14th May 2010, 22:33
  4. Demuxing True-HD sound to convert to ac3
    By out_sider in forum Blu-ray Ripping
    Last Post: 22nd Jan 2010, 15:44
  5. Make an xvid/avi from DVD but keep original ac3 surround sound?
    By coolchris in forum Newbie / General discussions
    Last Post: 26th Jan 2008, 07:35
