What is a good program to use for converting Blu-Ray (M2ts) files to DVD (VTS) files?
In the past I have had sucess using WinAvi but for some reason can't get it to work anymore. Don't know if I had a certain codec installed to have it work or what?
Anyway, Help would be appreciated for I am a newbie in some ways.
Thread: M2ts files to DVD
I'm a victim of circumstance
there is no direct way. they would need to be re-encoded to dvd spec mpeg-2 and then authored to dvd vob and ifo files. there are some "all-in-one" type programs like convertxtodvd that will do everything for you.
Yeah, try ConvertXtoDVD
Thanks. I will give it a try and let you know how it works.
One other question.............
When converting these M2ts files after using AnyDvd I go to the movie title, BDMV, STREAM and find the movie file there. I then load the file into whichever converter program I am using to convert it to a DVD file I can play on my stand alone player.
Is that pretty much the correct procedure?
Like I said, sometimes it works using WinAvi but sometimes not. I will try the ConvertX thought.
Thanks again youz guyz. I really appreciate it.I'm a victim of circumstance
How to burn HD movie files (.m2ts, .mp4, .mkv) to standard DVD
By neworldman in forum DVD RippingReplies: 4Last Post: 17th May 2010, 11:01 -
Help with multiple .m2ts files to one .m2ts
By neworldman in forum Blu-ray RippingReplies: 7Last Post: 17th Mar 2010, 19:39 -
m2ts files on DVD with MultiAvchd
By besthost in forum Authoring (Blu-ray)Replies: 2Last Post: 3rd Jul 2009, 04:06 -
Playing multiple m2ts files on PS3 from a DVD
By dieselgg in forum Authoring (Blu-ray)Replies: 2Last Post: 20th Jun 2009, 09:47
Statistics
Newest guides
Latest tool updates
New media comments
