Hello people,
i've just buy a new superb MP4 with a ~large 2.8" tacticle screen.
i was so excited to watch video on it...
but this MP4 player support only one video format![]()
but ok, the player come with a software (AVIConverter) how is already setuped to produce the right kind of file
BUT this software dont read enough entry format
so, no problem i was thinking, like usually i will use SUPER (or what ever) to Transcode this.
but no![]()
i've try many option,format and each time my player dont want play them....![]()
so here the specification of a vidéo file produce with the included Software (AVIConverter)
info from MediaCoder
here a direct link to the videoOriginally Posted by mediacoder
in SUPER i have try this->
but dont work.. what can i do ?
The working video has no b-frames, and several duplicate frames (choppy playback). I don't know how to set that in super, but you can specify no b-frames encoding xvid in virtualdub , avidemux, or megui . Your 20 fps is problematic, because if you don't do the conversion right, you will get audio/video desync and/or choppy playback - do you know if your player is capable of other fps for playback?
Hi thank's for your reply...
i dont know if my player support other rate than 20fps because the only Video file how ever work is the file converted with the included software, and he produce 20fps files...
ok i will try with Megui tomorrow thx.. (i let you know..)
You still might have problems, because of the frame repeats etc... (the AVID, DF parameters in the gspot shot) , also the xvid version is very outdated.
If using no b-frames still doesn't work, another strategy would be to encode to a (hopefully) lossless format (e.g. lagarith in avi container) that the player's encoding software accepts
hi the problem is not the Bframe because SUPER by default dont add Bframe ->
so your second solution is to encode into AVI format that the "included encoder" can encode in this strange format that it ?
if yes i already think of this posibility but that take more more time ton convert many video
that why i want find the right setting fot this strange format...
maybe a link to the included encoder will be useful ?
i found a way !!
so the provided encoder, only accept in input few file format (mp4,avi,mpg,mkv and that all)
but for all my FLV and M4V i simply rename the extention into MP4 and it work !!
Yesssss (so lucky
thx for your support..
hi! Please explain how you got the encoder to work. I also have a video player. It's a touchscreen fake ipod touch and really cheaply built. It also came with avi converter. Please send me instructions on how to encode video. thanks!
hi again. Also, if you can help me figure out which codecs to use, maybe we can use a batch encoder somewhere where we won't have to use Avi Converter, which takes a while to load in all the videos. A batch encoder, like SUPER, would work so much better!!
How Do I Convert an MP4 file to Windows Movie Maker format?
By gasjkh22 in forum AudioReplies: 7Last Post: 28th Aug 2011, 05:13 -
What is the best convert MP4 to DVD format and for the internet
By robthgeek in forum Newbie / General discussionsReplies: 1Last Post: 27th Aug 2011, 15:12 -
What the best format to convert to, AVI(Xvid), MP4 or MKV
By adamf154 in forum Video ConversionReplies: 2Last Post: 1st Mar 2010, 16:48 -
Convert to MP4 format
By dvrvarma in forum Portable VideoReplies: 4Last Post: 13th Nov 2009, 11:09 -
What's the better way to record/convert mpeg and mp4 format?
By Mark WR in forum Video ConversionReplies: 0Last Post: 11th Aug 2008, 17:21
