I know most people would say H.264 since it compresses better at lower bitrates, but I'm planning on re-uploading some of my videos as close to the 1 GB range as possible so file size doesn't matter. Yeah, 1 GB might be too much, but it doesn't take me long to upload a 1 GB file (I've tried it before with a 4 minute DV clip). I would also like to upload with uncompressed audio. I know MPEG-2 can do it, but there is a bitrate limitation and, as far as I know, only authoring programs can do it. A 8 Mbps video with 1536 PCM would work, but I can't figure out a way to join a 15-20 Mbps clip with 1536 PCM. And what about H.264, is there a way to encode to H.264 with lossless audio? Here are a couple examples of what I want to do:
- HD Video
MPEG-2
Resolution: 1920x1080 or 1280x720 (whichever is better for youtube)
Bitrate: 15 Mbps
Audio: 1536 PCM
or
MPEG-4/AVC
Bitrate: 15 Mbps
Audio: Lossless if possible
SD Video
MPEG-2
Resolution: 720x480
Bitrate: 25 Mbps
Audio: 1536 PCM
or
MPEG-4/AVC
Resolution: 720x480
Bitrate: 25 Mbps
At those settings, what format is better for youtube? I'd go with Lagarith/MSI AVI if I could but unfortunately I can't get them to upload properly so I'll have to work with either MPEG-2 or H.264.
Thread: H.264 or MPEG-2 for Youtube
if you go with mpeg-4 you can use aac at up to 640kbps, about as loss free as it gets. do some demo tests as for the best video bitrate to suit your videos, anything over 4-5 mbps will convert well and get a watch in HD link, if it's 720p or better. the sd isn't going to get watch in HD or HQ no matter how high you make the bitrate. you will have to convert to 480p for HQ or 720p for HD links, if that is what you are after.
lagarith and other lossless video types are not accepted at youtube.
Already tried TMPGEnc PlusOriginally Posted by seven_deuce offsuit
ffmpeg or MEncoder should do it too, in theory at least.
How would I be able to do it with ffmpeg, 25 mbps MPEG-2 + 1536 PCM?
Code:mencoder video.m2v -audiofile audio.wav -oac copy -ovc copy -o output.mpg
I appreciate your help but perhaps you can give me a step by step solution? I'm a complete newb when it comes to scripts, or just ffmpeg for that matter.
Encode YouTube video to MPEG-2
By RL in forum ffmpegX general discussionReplies: 4Last Post: 31st Jan 2011, 23:31 -
YouTube recommendation... H.264 + MP3... possible?
By Bubblevision in forum Video ConversionReplies: 5Last Post: 15th Oct 2009, 06:25 -
converting Format 35 Youtube video to H.264 on Mac for iPod viewing
By Tokyoguy in forum MacReplies: 12Last Post: 31st May 2009, 00:33 -
H.264 (MOV) to H.264 MPEG TS conversion
By svens in forum Video ConversionReplies: 0Last Post: 19th Feb 2009, 06:47 -
DV to H.264 MPEG-4
By Aristophanes in forum MacReplies: 0Last Post: 21st Apr 2008, 02:37
