I have a AVI file that has a director's commentary audio track over top of the other audio. The audio is mpeg layer 3 and have tried tsMuxeR but mpeg layer 3 does not seem to be supported. I have used dvd shrink to remove the commentary track off a video_ts folder but this file does not seem to be supported there either. Is it possible to remove this commentary audio off of this file so I can burn it? Thanks![]()
Open the AVI in virtualdubmod. Click on Streams -> Stream list.
If there is only one audio stream listed, close virtualdubmod, delete the file, and learn from the exercise.
If there are two audio streams, disable the one you do not want, then save a new copy of the AVI using Direct Stream Copy mode for both video and audio. This will give a new version with just the audio you want, and no re-encoding. Should take around 5 minutes all up.
How to choose audio track in avi file with two audio tracks
By newnews in forum AudioReplies: 3Last Post: 26th Oct 2010, 05:26 -
removing one audio track from an avi movie file
By srckaimal in forum AudioReplies: 1Last Post: 4th Nov 2009, 19:28 -
how to convert codec mpeg 2 layer3 to mpeg 1 layer3
By sumeshkri in forum AudioReplies: 7Last Post: 20th Aug 2009, 04:04 -
using VOB2MPG to convert WITHOUT the commentary audio track
By wildrthanevr in forum Video ConversionReplies: 4Last Post: 16th Mar 2009, 11:57 -
How to use only one audio track from a 2-audio-rack .avi File
By akulier in forum ffmpegX general discussionReplies: 2Last Post: 21st Feb 2008, 03:28
Statistics
Newest guides
Latest tool updates
New media comments
