I have a bunch of flv clips i want to combine. The way I tried was to convert them all to avi using anydvd converter, but the audio went out of sync. So what is the best way to combine these clips, so that audio/video sync is maintained?
If they all have exact same settings you could try use Movica but I suspect they are different, try then convert them all to avi using WinFF instead(avi with xvid with mp3 audio for example). Check so they are in sync and then join lossless using for example virtualdub or avidemux.
I actuallu used DVDFlick to combine the flv clips, a process that took 4 hours, and there is no loss in sync. But I was wondering if it could be done faster. Someone said windows movie maker can do this, so I am goin g to try it
If you want a DVD then you can try ConvertXtoDVD. Faster then DVDFLick but not free then.
Combine clips in Sony Vegas (NOT GROUPING!!)
By Compo in forum EditingReplies: 31Last Post: 7th Jan 2014, 15:00 -
How to Combine MP4 Clips and then to WMV & AVI
By gonwk in forum Video ConversionReplies: 3Last Post: 2nd Mar 2010, 08:35 -
Cut clips from home DVDs and combine them with Pinnacle
By avz10 in forum EditingReplies: 9Last Post: 6th Feb 2010, 15:06 -
Combine multiple FLV files in one flow.
By nevsky in forum Video Streaming DownloadingReplies: 0Last Post: 24th Jan 2009, 07:06 -
Combine multiple DVD clips in Adobe Premiere Pro
By Benhermies in forum Newbie / General discussionsReplies: 1Last Post: 16th May 2008, 11:55
