Okay, I was working on a project with YouTube-downloaded videos (mpeg2 I believe) with Adobe Premiere Elements 7.0
My computer gets a virus, and I backup all of my project files, and I reformat my hard-drive. I re-install Premiere Elements 7.0, and I open up my project. None of the clips are working. They're all "offline". Every time I try to locate one of the videos, it says "Add Media Failure: This type of file is not supported, or the required codecs are not installed."
I tried making a new project and importing the videos.
I tried re-installing Premiere.
I have the same codecs I had before (DivX and K-Lite Codec Pack. I've tried older versions, and I've tried doing it without the codecs. No dice)
You may need an FLV splitter and FLV1, VP7, and h.264 decoders. MediaInfo or GSpot can tell you what you need.
Importing MPEG-2 videos on Premiere Pro on OS X Lion
By Atoon in forum MacReplies: 1Last Post: 1st Feb 2012, 04:08 -
Importing 3GP videos to iMovie 11
By curt00 in forum MacReplies: 2Last Post: 3rd May 2011, 11:23 -
Trouble Importing avi file into Adobe Premiere
By Top Gun in forum Newbie / General discussionsReplies: 8Last Post: 18th Jul 2010, 14:21 -
Having trouble importing older GFD projects.
By usually_quiet in forum Authoring (DVD)Replies: 2Last Post: 2nd May 2008, 18:15 -
Magix Edit pro 12 trouble importing from DVD
By patsy in forum Newbie / General discussionsReplies: 0Last Post: 19th Jun 2007, 13:03
