Recently received this unit and it is great.
One question, when I view movies that I have downloaded onto a usb flashdrive I can't use fast forward or reverse. Am I doing something wrong ?
Thread: Phillps 5990 - usb operation
Perhaps. I haven't had a problem moving through videos copied to a USB pen drive. If you open the videos in GSpot or VirtualDub (for starters), do they complain about the videos' index?
What keys (on the remote) are you using to cue?If cameras add ten pounds, why would people want to eat them?
It is ok now. Ocasionally I seem to be hitting some combination of keys that prevents the forward/reverse (on the round key area) from working.
If you are watching a movie on the usb and decide to use the Disk instead, can you get there without shutting it off and on ?
Yes, you hit the USB key on your remote...#14 on the diagram below. That will toggle you between USB and Disk.Originally Posted by bobbee25
Philips DVP 5990 USB question
By Estam in forum DVD & Blu-ray PlayersReplies: 2Last Post: 6th Dec 2010, 14:20 -
USB Problem with Philips DVP 5990
By bufbt in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2010, 12:52 -
Philips 5990 & ext. HD via USB
By Ruut in forum DVD & Blu-ray PlayersReplies: 10Last Post: 27th Dec 2009, 16:07 -
dvp 5990 usb freezing problem?
By mtlbrad in forum DVD & Blu-ray PlayersReplies: 0Last Post: 18th Oct 2009, 14:11 -
Philips 5990/12 - wrong aspect ratio @ DivX via USB
By blackfrogg in forum DVD & Blu-ray PlayersReplies: 9Last Post: 30th Jan 2009, 08:09
Statistics
Newest guides
Latest tool updates
New media comments
