I have a m2ts with LPCM 5.1 and Dolby 5.1 (448kbps). Since my AV receiver doesn't support LPCM, I have converted the LPCM to DTS file using eac3to. I want to add this DTS track in place of the Dolby (448kbps) of the m2ts video file. Kindly suggest me the method or program to remux without touching the video of the m2ts.
Results 1 to 10 of 10
Thread: Remux m2ts with DTS to m2ts
I have tried tsmuxer, after I first added the m2ts and then adding the DTS file it shows error message "Can't detect stream type".....
Are you sure you have a valid DTS file ? It works for me. Use the tsmuxer beta 1.8.24 or later
I tried tsMuxer beta 1.8.24 but still getting error msg "Can't detect stream type". Let me start from scratch. Pls guide the best method to convert the LPCM in a m2ts file to DTS and will try remuxing with tsMuxer.
That error message occurs when you don't have a valid file type i.e. there is likely something wrong with your dts encode. Check the eac3to log file for more info.
Do you have surcode, for dts encoding ? Eac3to will use it automatically, and it is required
Can you play the dts file in a media player? e.g. mpc, vlc, mplayer ?
What does mediainfo say about your dts file?
EDIT: yes you're right, the header information written by the eac3to output is not read correctly by tsmuxer. It works with other .dts files...
OK, Here's a workaround: you can re-wrap the eac3to .dts file with mkvmerge. If it's only audio, it will use "mka" extension, you have to rename to "mkv", then tsmuxer will accept it and it will work with a remux
Cheers
Thanks for your input and I followed your method. But now after adding both the m2ts and mka file and then selecting the output as m2ts and on clicking on "start muxing" (in both versions: 1.8.8 and 1.8.24beta) it gives error message "Unsupported container format: E:\s-audio.mka".Originally Posted by poisondeathray
Pls help....
When I use TsMuxer on DTS-HD discs the audio is not recognizable by BD RebuilderOriginally Posted by poisondeathray
eac3to's audio output of TrueHD is not recognizable by BD Rebuilder
I use TsMuxer on TrueHD
I use TsRemux on DTS-HD
ocgw
peaceAthlon II Propus 630 @ 3.62Ghz / 8GB DDR2 1066 5-7-7-20 / 8x BD-RW / 19TB Storage
http://forum.videohelp.com/topic368691.html
Please re-read my instructions above: you have to rename extension .mkv from .mka.Originally Posted by eummagic
Thanks.....I missed that step....it is now working fine.....Thanks once again!
80% MKV remux on H.264 - M2ts remux Aero Theme
By BJ12 in forum Video ConversionReplies: 2Last Post: 12th Aug 2011, 12:59 -
Can remux .mkv to .m2ts with tsMuxer but how to do the reverse?
By MilesAhead in forum Video ConversionReplies: 8Last Post: 22nd Apr 2010, 14:27 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 12:10 -
demux m2ts streams and remux them together with srt subtitles
By TwilightMatt in forum Video ConversionReplies: 5Last Post: 9th Dec 2009, 11:10 -
remux to (TS vs M2TS)
By Data-Base in forum Video ConversionReplies: 2Last Post: 19th Apr 2009, 15:50
