I want to cut few AVI files created by Sony Movie Shaker program, but every time I try to use VirtualDub 1.4.8 I get this error
"Couldn't locate decompressor for format "dvsd" (unknow)
VirtualDub requires a Video for Windows (VFW) compatible codec to decompress video. DirectShow codecs, such as those used by Windows Media Player, are not suitable."
what I am doing wrong!
I need help! to solve this issue I am using WinXp pro
Thank you
El Serch![]()
Thread: VirtualDub error message
hehe I asked that 3 days ago.. No reply yet.... (p.s) I even provided a screenshot and took the time to upload it!
And possibly all of us have Windows XP.
Possibly this is because
Microsoft has decided to stop support of VfW drivers with Windows XP onwards
(see http://www.puremotion.com/videoediti...versexplained/)
I had the same problem. Luckily I had a Win2k machine with StudioDV on it. Since I don't use that machine for DV any more I figure it's ok to use some of StudioDV on the XP machine (its version 1.02 which isn't supported on XP)
I searched the registry for dvsd - found it under
HKLM\Software\Microsoft\Windows NT\CurrentVersion\drivers32\vidc.dvsd
description is at
HKLM\Software\Microsoft\Windows NT\CurrentVersion\drivers.desc
Copied these two entries to a .reg file.
Used depends (http://www.dependencywalker.com) to work out which dlls I had to take with the one named in vidc.dvsd
Moved the dlls to windows\system32 on the XP machine and added the registry entries and voila - VirtualDub works agains DV avi files.
Presumably this is what other people have done by installing the panasonic codec - I just wanted to make sure I could undo the install if it didn't work.
I had a same problem too
. I'm also using winxp
She's my idol,
She's the best,
She's Ruby Lin...
Ruby4evaaaaa!!!
Virtualdub Error Message - Failed to load FFmpeg.dll
By SOSmkII in forum Video ConversionReplies: 5Last Post: 6th Feb 2012, 07:14 -
Opening Avisynth script on virtualDub - Error Message
By HugoBraule in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2010, 21:48 -
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 01:16
