Hello everybody
Great forum.
I have this excellent DVD player and I know the USB port can be used to plug pen drives, external hard drives etc. to play music, movies.
I was wondering however, if it is possible to connect a laptop (or a desktop) in place of the USB stick to have a little more control on the files available to the player. Is this is a stupid question or what ?
Has anyone tried that ?
Regards
Thread: Philips DVP5990 - USB port usage
your player will only recognize a mass storage device . I.E. It acts as master/Host in the USB chain, PC also trys to act as HOST thus incompatible. There is even the possibility of damage if you somehow do connect the two
GG/Wiki - (usb a Usb B leads)Corned beef is now made to a higher standard than at any time in history.
The electronic components of the power part adopted a lot of Rubycons.
Whatever you do, don't connect a computer usb port directly to the usb port of the player with a standard usb cable.
I don't have one so don't know if a usb bridge would work.There's not much to do but then I can't do much anyway.
Philips DVP5990 Issue
By TheStranges in forum DVD & Blu-ray PlayersReplies: 3Last Post: 16th Dec 2010, 22:56 -
Which hdtv's have a USB port, so you can plug in a flash drive or USB HDD?
By snafubaby in forum DVB / HDTVReplies: 8Last Post: 30th Nov 2010, 16:03 -
Philips dvp5990
By tqworld in forum DVD & Blu-ray PlayersReplies: 4Last Post: 18th Jun 2010, 17:24 -
Philips DVP5990/F7 freezes
By flyboynm in forum DVD & Blu-ray PlayersReplies: 0Last Post: 7th Mar 2010, 15:46 -
Philips DVP5990 (80,60)
By hujercz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Dec 2008, 03:57
Statistics
Newest guides
Latest tool updates
New media comments
