I've tried to use MKVextract to extract the subtitle streams (idx/sub) from the mkv file, but it seems that there is a problem with the mkv file itself. It only extracts the subtitles partially (i.e. first 40 Minutes only). I'm wondering if there is a solution for this problem. By the way, I can play the mkv file without any problems using Media Player. I think there is a glitch in the mkv file that is causing this problem.
Any suggestions?
Software players are usually more forgiving of errors in a video file than anything else (converters, hardware players, etc.), so it's not uncommon to see other programs having problems with a video while a software player doesn't.
Are you sure you're using the latest versions of mkvtoolnix and MKVExtractGUI, both installed to the same directory?If cameras add ten pounds, why would people want to eat them?
Thanks for your reply Ai Haibara,
I made a clean installation for Windows XP and then installed the latest version of mkvtoolnix and MKVExtractGUI from Videohelp. The problem is still there. I'm wondering if there is a tool for mkv files that would do to them what DivFix tool used to do for divx files.
You can try re-wrapping the mkv with mkvmergegui (i.e. make a new .mkv by repackaging it, so if there was damage in the structure, it might fix it), then try mkvextract
If that doesn't work , try re-wrapping with gdsmux (haali muxer, comes with the haali splitter package), then mkvextract
Hi poisondeathray,
Thanks for your feedback.
Using mkvmergegui & mkvextract yielded the same results as mkvtoolnix and MKVExtractGUI did (i.e. first 40 Minutes only).
When I tried gdsmux, it is stuck at 1.4% and doesn't move.
Maybe you can try avimux-gui
Well, there is some progress here. 41 Minutes generated
Here is the log file from avimux-gui, if anyone can benefit from it:
Code:02:16:46.234 Creating Matroska v1 file 02:16:46.234 Matroska file specification will not be stretched 02:16:46.328 size of floats: 32 bits 02:16:46.328 Using own cache for output file: Yes 02:16:46.328 Using 4 cache lines of 2,048 kBytes each 02:16:46.343 Begin muxing... 02:16:48.640 Estimated raw stream size: 1,463,584,010 bytes 02:16:48.656 Estimated overhead: 6,526,372 bytes 02:16:48.656 Estimated total size of output: 1,470,110,382 bytes 02:16:48.656 Size of files being overwritten: 320,316,628 bytes 02:16:48.656 Free disc space on target: 497,311,358,976 bytes 02:16:48.656 unbuffered write enabled 02:16:48.656 asynchronous output disabled 02:16:48.656 new file at 0:00:00.000 (frame 0): D:\DVD Rebuilder\The Right Stuff.mkv 02:16:48.656 Output timecode scale: 500,000 02:16:48.656 random element order enabled 02:16:48.656 Cues for video stream enabled 02:16:48.656 Cues for audio streams enabled 02:16:48.656 Cues for subtitles enabled 02:16:48.671 writing CueBlockNumber 02:16:48.671 Clusters will not be indexed in seekhead 02:16:48.671 Lacing for video stream is off 02:16:48.671 number of audio streams: 2 02:16:48.671 track: 1 02:16:48.671 lace size: 200 ms 02:16:48.671 language code: fre 02:16:48.671 track: 2 02:16:48.671 lace size: 200 ms 02:16:48.687 language code: eng 02:16:48.687 number of subtitles: 4 02:16:48.687 track: 1 02:16:48.687 language code: mis 02:16:48.687 subtitle format: VOBSUB 02:16:48.687 compression: zlib 02:16:48.687 track: 2 02:16:48.687 language code: fre 02:16:48.687 subtitle format: VOBSUB 02:16:48.687 compression: zlib 02:16:48.687 track: 3 02:16:48.687 language code: eng 02:16:48.703 subtitle format: VOBSUB 02:16:48.703 compression: zlib 02:16:48.703 track: 4 02:16:48.703 language code: ara 02:16:48.703 subtitle format: VOBSUB 02:16:48.703 compression: zlib 02:16:48.703 size of headers: 197,294 bytes 02:16:48.703 Cue target size: 98.0% of the available space 02:17:01.187 614 clusters written causing 16,533 Bytes of overhead 02:17:01.187 track 1 02:17:01.187 EBML lacing used in 8,957 blocks containing 58,886 frames Size of lace headers: 73,711 bytes 02:17:01.187 fixed lacing used in 1 blocks containing 5 frames Size of lace headers: 1 bytes 02:17:01.203 track 2 02:17:01.203 EBML lacing used in 8,958 blocks containing 58,891 frames Size of lace headers: 70,188 bytes 02:17:01.843 Created 2,453 cue points, 2,453 of which have been written 02:17:01.906 Size of seekhead: 512 bytes 02:17:01.906 Overhead written: 1,408,183 bytes 02:17:01.906 done! 02:17:01.921 =========================================
Do you still have the original source? e.g DVD ? maybe you can re-rip the subs?
You can sometimes find .srt subs on subtitle databases, but rarely idx/sub
How was the .mkv damaged?
Try ogmcleaver ... not hopeful though
MKVExtract won't extract subtitles from my .MKV file
By pepperjinks in forum SubtitleReplies: 12Last Post: 14th Mar 2012, 20:16 -
How to extract subtitles from MKV videos to convert them to AVI
By zikegi in forum Video ConversionReplies: 0Last Post: 15th Sep 2011, 20:47 -
Extract from avi file and add to existing mkv file
By pathumx in forum MacReplies: 6Last Post: 8th Apr 2010, 18:57 -
Extract subtitles that is "in" the .mkv-file ???
By kulmagen in forum SubtitleReplies: 4Last Post: 24th Oct 2009, 23:04 -
How to extract Subtitles from .MKV files?
By kehn in forum SubtitleReplies: 4Last Post: 20th Nov 2007, 06:14
