VideoHelp.com Forum
    Hello,
    I have been recording onto DVD+RW for months with the Goodman DVDG306R but I've recently been running into problems with the DVD being read. I'm not sure is it the Recorder or the disks that is the problem. I don't think it's the disks as I've been trying on fresh disks. Is there any program I can use on Linux to reformat the disks to make sure there's no issue with the disk.
    Regards,
    David
  2. Get Slack disturbed1's Avatar
    Nero Linux can format, or K3B and Gnome's built in media burner will blank the RW.
    dvd+rw-format -force=full /dev/dvd
    dvd+rw-format /dev/dvd
    Where /dev/dvd is your dvd burner.
    BTW, DVD+/-RW are only good for so many writes. ~1,000 or less, usually much less. Depending on the quality of the disc, some degrade in as little as 10-20 rewrites.
    Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
    I've been having the same problem on Memorex DVD+RW with LG RC700N DVD Recorder + VCR. I too need to format these DVDs and I was wondering if the media code can say anything about what went wrong in trying to format the DVD with LG. The given information is from the DVD.
    Unique Disc Identifier : [DVD+RW:INFODISC-A10-001]
    Disc & Book Type : [DVD+RW] - [DVD+RW]
    Manufacturer Name : [Infodisc Technology Co. Ltd.]
    Manufacturer ID : [INFODISC]
    Media Type ID : [A10]
    Product Revision : [001]
    Blank Disc Capacity : [2,295,104 Sectors = 4.70 GB (4.38 GiB)]
    Recording Speeds : [1x-2.4x , 1.6x-4x]
    [ DVD Identifier V5.2.0 - http://DVD.Identifier.CDfreaks.com ]
    ** INFO : Data Below Is Formatted For www.VideoHelp.com/DVDmedia
    ** INFO : 4-Byte Header Present
    ** INFO : Format 11h - ADIP Information
    Complete DVD Media Code =
    00 00 00 00 92 0f 04 00 00 03 00 00 00 26 05 3f .............&.?
    00 00 00 00 00 00 01 49 4e 46 4f 44 49 53 43 41 .......INFODISCA
    31 30 01 39 23 00 9c 7c 5c 02 28 00 96 7e 70 02 10.9#..|\.(..~p.
    28 00 9c 7b 68 02 28 04 04 20 e0 00 f0 00 00 00 (..{h.(.. ......
    DVD Media Type=DVD+RW
    DVD Media Code=INFODISCA10
    Also is applying a DVD lens cleaner good enough for maintenance of these DVD Recorders?
  4. Member FulciLives's Avatar
    ImgBurn works under Linux if you have WINE installed.
    - John "FulciLives" Coleman
  5. Get Slack disturbed1's Avatar
    Hey John, just wondering - what would/can IMG burn do that can't be done with Nero Linux, or in the case of free - K3B? I know many people didn't know that Nero Linux can read MIDs and set book type, but so can cdrecord (cdrecord -media-info/ -minfo/-atip) and DVD+RW-tools (dvd+rw-mediainfo), dvd+rw-booktype to set the book type.
    It's been a while since I've looked at IMG burn
  1. Formatting a DVD+RW
    By V Bot in forum Media
    Last Post: 28th Jul 2009, 14:09
  2. Replies: 5
    Last Post: 26th Nov 2008, 20:27
  3. Formatting a rewriteable DVD?
    By c5vetman in forum Media
    Last Post: 27th Mar 2008, 02:05
  4. Formatting a dvd-rw 4.7gb
    By IOMEGA in forum Newbie / General discussions
    Last Post: 13th Nov 2007, 14:56
  5. Replies: 0
    Last Post: 28th May 2007, 10:23
