VideoHelp.com Forum
    Hello,
    I have been recording onto DVD+RW for months with the Goodman DVDG306R but I've recently been running into problems with the DVD being read. I'm not sure is it the Recorder or the disks that is the problem. I don't think it's the disks as I've been trying on fresh disks. Is there any program I can use to reformat the disks to make sure there's no issue with the disk.
    Regards,
    David
  2. Member Krispy Kritter's Avatar
    The easiest thing to try would be a different brand/type of disc as this type of issue is typically media related. Stick with a quality media such as Verbatim as they are the most reliable and consistent.
    Google is your Friend
  3. deithi_dearg
    Do not know for sure but the Goodman might be a clone of liteon
    Either way the use and operation of a +RW disk should be the same
    The following is how I delt with problems with the RW disks use and I have had NO problems since
    I first FULLY erased In A PC all +RW Disk that were a problem
    [Important] I DID not ALLOW the PC software to Format The Disk. To do a PC format might confuse the recorder and cause it to reject the disk
    I put the disk back in the stand-alone [It should be recognized as a blank disk] than fully erased it, this prepared and formatted it to the units liking
    [Important] I do not erase segments of a disk. If filled or partially filled,To do so and than feel the disk is erased [could result in an error] I erase the entire disk With the Unit..
    This was a number of years ago and I have had not 1 Problem since, and do not use any PC or software
    As to disks
    I have mainly used Verbatim and Ridata, some TY, Maxel and others.
    The +RW were mainly Verbatim and some Maxel. The Maxel were supplied by a user and I have Not had any difference in operation or performance
    EDIT
    While I don't generaly care fot Nero its full erase works fine for the purpose
  1. help recording my laptop with dvd recorder
    By xtube in forum Newbie / General discussions
    Last Post: 11th Aug 2010, 11:41
  2. VHS To DVD Recording errors
    By DuBsTaR in forum Newbie / General discussions
    Last Post: 14th May 2010, 12:31
  3. DVD Recorder, TV Recording, and Interlace Question
    By CobraPilot in forum Authoring (DVD)
    Last Post: 20th May 2008, 19:53
  4. Recording from one DVD recorder to another?
    By Trollheart in forum DVD & Blu-ray Recorders
    Last Post: 17th Mar 2008, 16:54
  5. Problem with recorder? Skipping only when recording on DVD
    By fastheart in forum Newbie / General discussions
    Last Post: 25th May 2007, 10:26
