I recently tried to create an MKV file with the following streams:
Video 1.MP4 - 407.4MB (H.264 encoded file, no audio)
Sub 1.srt - 64KB
Audio 1.MP3 - 55.3MB (LAME encoded file)
Audio 2.MP3 - 55.3MB (LAME encoded file)
When I mux the file with MKVToolnix (GUI), I seem to get a file with a size of 703.5MB and not around 520MB (the added totals of all the streams). I understand if it's a little higher then 520MB for the MKV container info, but an extra 200MB seems absurd. Does anyone have an explanation for the 200MB of bulk?
Thread: Muxing MKVs adds 200MB
I've never seen this happen and I use mkvmergegui often.
Are you using the newest version 2.5.2 ?
Are you sure the 4 streams are the only contents?
Can you try it again?
What if you use gdsmux (comes with haali splitter package) ie. haali mkv muxer?
I'm on OS X, so I can't use mkvmergegui or haali splitter.
Also, MKVToolnix uses version 2.5.1 of mkvmerge to my understanding. And I have to select each stream to add by hand, so it doesn't appear that I added more then those 4 streams.
2.5.2 is the lastest version, for Windows at least, not sure about mac
http://forum.doom9.org/showthread.php?t=120648
http://www.bunkus.org/videotools/mkv....5.2-setup.exe
Not sure if this is a mac issue?
Hardsubbing MKVs
By Zepwich in forum SubtitleReplies: 5Last Post: 19th Aug 2011, 16:07 -
MKVs into CS5.5
By mavermc in forum Video ConversionReplies: 4Last Post: 26th Jun 2011, 12:09 -
Why is Sony Vegas only 200mb and other editors a few GB?
By vidds in forum Newbie / General discussionsReplies: 4Last Post: 17th May 2011, 04:11 -
Blocky MKVs
By romanticwarrior in forum Authoring (Blu-ray)Replies: 4Last Post: 2nd Dec 2010, 15:06 -
Joining MKVs
By Maajid in forum Video ConversionReplies: 0Last Post: 1st Aug 2010, 09:21
Statistics
Newest guides
Latest tool updates
New media comments
