I have a Sony Camcorder that records in Vob format. I copied the original files from one of my disks to my computer, then erased the disk. Wish I hadnt done that.....if I still had the original disk, I could easily use the Sony Picture motion software to convert the files to mpeg.
However, I dont have the original. Is their a program that can do this? I tried PE 3.0 and the results were horrible. I tried vob2mpeg and some others like it, but did not get a good result.
Any ideas?
Thank you
Results 1 to 9 of 9
What does "did not get a result" mean ? Can you be more specific? vob2mpeg doesn't re-encode so I can't imagine worse quality...
vob2mpeg doesn't change anything in the video, it's just the original in a new wrapper. any complaints about the quality would be in the original also.
I keep getting a Finished processing 0 subsets message. I directed the folder containing vob sets to the folder that contained the vob file itself. Do I need to direct it somewhere else?
sometimes you have to click on the start button twice before it processes
I clicked start 10 times and it keeps saying finished processing 0 subsets.
Does the folder I direct the program to only have to contain the VOB files, or does it also have to have the iso, bup, etc files?
just vobs will work if they are numbered consecutively.
Im directing the program to a folder that only has one vob file in it and its still not working.
Any other programs that will do this for me without quality loss?
I tried renaming the file with the extension mpg, but when I played that file, it acted strangley....fast forwarding itself, then stopping, then fast forwarding again.
how to convert mkv or vob to mpg or mpeg
By ashe09 in forum Video ConversionReplies: 4Last Post: 11th Oct 2011, 04:46 -
By ashe09 in forum Video ConversionReplies: 2Last Post: 11th Oct 2011, 04:05 -
Urgent -What do I need to convert VOB files to mpeg or form for internet
By acidophulus in forum Newbie / General discussionsReplies: 6Last Post: 5th Jan 2010, 11:39 -
Convert videos from .VOB format to MPEG?
By hawkeyed76 in forum MacReplies: 5Last Post: 10th Sep 2007, 01:10 -
How to convert IFO/ Vob to mpeg (sony DVD camcorder)
By Guthix in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 23rd May 2007, 18:05
