VideoHelp.com Forum
Results 1 to 11 of 11
    Hi Guys,
    I have spend many time to make a nice slideshow from my vacation. I am a german guy and I donīt canīt find a answer to my problem. My slideshow have 620 pictures. If i want to export the slideshow in any format i get these messages.
    To the last message: It is impossible, i have 80gb free space!
    My system: Win Xp Pro SP3, Intel Pentium 4 3,4Ghz, 2Gb Ram, 250Gb HDD
    I hope my english is not so bad and somebody can help me.
    Thank You
    Greetz David
  2. Member Soopafresh's Avatar
    Post your AVS file
    Is your hard drive formatted NTFS or FAT32? FAT32 has a 4GB file size limit.
  4. Make sure that you got enough free harddiskspace on the drive, where you installed DVD slideshow GUI(typically C: ) and also the drive you're exporting to. When exporting a lot of temp flies are generated like a 2 MB downscaled image each for each slide... Check those drives freespace when exporting to see if it's actully out of space.
    If you need hhd space then check for and delete "..._temp" folders in the DVD slideshow GUI main folder. Normally they should be cleaned out automatically after succesful exports.
    If you think you got enough free hhd space export your slideshow as ".avs" and drag and drop that file onto mplayerc.exe in the main DVD slideshow GUI folder and see if it comes up with an error message. Post what is says here.
    When rendering 620 slides a lot of RAM is needed - since the entire video is loaded into the RAM before rendering. Hit Ctrl+Alt+Del to follow the usage of RAM when rendering. Add more virtual RAM if needed. (animated slides eat up more memory - so avoid those)
    I never rendered a slideshow with that many slides myself. Alternatively you can render your slideshow into smaller parts(avi) and join them in a new slideshow project consisting of the avis rendered with a safearea x,y=0.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    PLEASE use a better subject. I have changed it for you this time...you could also edit it by just click on the edit button on your first post.
    Morning together,
    Baldrick I donīt understand what you mean with use a better subject? Sorry my english is only a bad school english.
    I have enough free hdd space on the hdd where dvd slideshow gui is installed and on the disk i wont export to for sure. The RAM ist between 60 and 70 percent. I think thats ok too. If i put the avs file in de mplayerc it donīt start, but i have no error message. I post my avs file and hope somebody have a good idea.
    Greetz David
    neuseeland%201.avs
    Is your HDD formatted as FAT32 or NTFS (as asked previously, but not yet answered)
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  8. Member hech54's Avatar
    620 Bilder?
    If you are outputting that as an uncompressed avi file...at
    full size(720x576)....that is going to be VERY large....yes?
  9. If i put the avs file in de mplayerc it donīt start, but i have no error message.
    When exporting '.avs' it wll first prepare the slideshow by saving all the scaled temp images - this should give you no problems if you have enough hhd space. You could check if a "..._temp" folder is created with 620+ ebmp files. Then drag the avs file into mplayerc.exe and waith until it says something or show you the slideshow, while doing this keep an eye on the RAM. 620 slides will take a long time to load. Dunno maybe more than 20 min?
    If this works okay then grab the gui version of HCenc and load the .avs file into that, to play around with the settings manually and render it.
    Btw. does it export okay if you have like 10 slides in the slideshow?
    So i have checked all oppinions that i have but it donīt works and i donīt find out why. I have changed the programm and than it works. Sorry guys but very thanks to your help!!!
    Nice Greetings David
  11. Btw. does it export okay if you have like 10 slides in the slideshow?
  1. DVD Slideshow GUI
    By spike47 in forum Newbie / General discussions
    Last Post: 15th Apr 2012, 12:23
  2. Little problem with DVD Slideshow GUI
    By kippax in forum Newbie / General discussions
    Last Post: 10th Jun 2011, 19:14
  3. Help with DVD Slideshow GUI, please...
    By MackoMaca in forum Newbie / General discussions
    Last Post: 1st Oct 2010, 11:31
  4. DVD slideshow GUI
    By andwan0 in forum Newbie / General discussions
    Last Post: 14th Sep 2010, 07:51
  5. Replies: 10
    Last Post: 19th Jul 2009, 22:00
