Hello there
I have just bought the DVDR 5570 from Philips and am quite happy with it. There is however something I haven't figured out. Your support would very much be appreciated:
The manual says that subtitles of DIVX movies should be played when carrying the same name as the movie (but with the file extension .srt). So pretty the same thing as on PC. However, when I try to copy .srt-files from a USB stick, those files are not recognised by the recorder and the movies won't show the subtitles. I have also tried to put the .avi and the .srt in a folder and copy the folder to the HDD, unfortunately the HDD only copies the .avi and omits the folder and the .srt.
Are there any suggestions how to solve the problem?
Thank you for your help and kind regards
C.
Try using short, all caps, 8.3 format file names like:
MOVIE.AVI
MOVIE.SRT
Good hint! Will try it out tonight at home!
Thanks a lot
C.
I fixed my Philips DVDR 3455H dvd/hdd recorder
By dphirschler in forum DVD & Blu-ray RecordersReplies: 48Last Post: 26th Feb 2011, 18:40 -
Philips DVDR-3480 DVD Recorder and Player 1080iâ€
By Vixfoxwatch in forum Newbie / General discussionsReplies: 5Last Post: 7th Nov 2010, 14:18 -
DVD Recorder Philips DVDR 3475/37. Help-me with region free.
By Aurelio in forum DVD & Blu-ray RecordersReplies: 1Last Post: 4th Sep 2007, 13:04 -
Philips DVDR 3390 - Can I capture to a PC with this recorder?
By muzicman82 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 2nd Jul 2007, 17:32 -
Philips DVD 160GB Recorder Model DVDR 3455H
By vsenapati in forum DVD & Blu-ray RecordersReplies: 2Last Post: 28th Jun 2007, 19:56
Statistics
Newest guides
Latest tool updates
New media comments
