VideoHelp.com Forum
    I have a PCI-e TV Wonder 650 currently working great in Vista 32bit using VMC for all my recording/watching.
    I only use it for OTA HD broadcasts via antenna.
    I can get a TV Wonder 650 USB at Circuit City for 40.00 since they are closing.
    Can I install the USB one on the same system so that I can record two TV shows at the same time?
  2. Member edDV's Avatar
    Depends on the capture software.
    Last week I went to nearest Circuit city and found nothing worth buying except an over priced Flight Sim throttle
    MCE will use the 650 for second cap at least for SD. I have no ATSC here so I dunno for HD OTA ATSC.
    http://www.kiva.org/about
    Damnskippy wants two OTA HD channels (one from each tuner).
    Good luck.
    http://www.vistaheads.com/forums/mic...-tv-tuner.html
    But for only $40, why not give it a try?
    Use the latest ATI drivers. If both tuners don't work, try these steps posted by HP (linked from ATI support site):
    http://h10025.www1.hp.com/ewfrf/wc/d...name=c01187871
    Also posted in Slysoft original thread.
    Bought it, installed it, and it works just fine
  5. Member edDV's Avatar
    Good luck.
    I've had two tuners working with MCE Vista (ATI 550 + Hauppauge HDR-1600) but from cable. So I don't haven't been able to try two ATSC.
  1. Replies: 4
    Last Post: 24th Feb 2010, 12:24
  2. I can't get my ATI tv wonder PCI 650 to capture
    By Onceler2 in forum Capturing
    Last Post: 28th Nov 2009, 09:47
  3. Replies: 3
    Last Post: 6th Nov 2009, 00:10
  4. Replies: 6
    Last Post: 13th Feb 2008, 12:58
  5. Replies: 0
    Last Post: 24th Jun 2007, 11:58
