I just bought an Insignia NS-2BRDVD and have tried burning discs using sony's handycam program in AVCHD format. It doesn't work. I was under the impression that most bluray players would support it. Anyone know anything about this? I've used the firmware upgrade. Lame if this is the case...
Thread: Bluray player won't play avchd
Give MultiAVCHD a try...........use DVDRWs to keep coasters to a minimum.
There is no such thing as "Idiot-Proof".........a good Idiot will get around that every time.
I've used multiavchd and it works great if you click create multibd instead of multiavchd. I just like the menu that sony creates better but their PMB only creates video in AVCHD. I'm ticked off this new bluray player I bought doesn't support it because it seems like everyone else and their mother can...thanks though.
Just curous.. Is there anything else (much smaller than multiavchd) that can make AVCHD structures ?
17mb is a bit high for my dialup, but I'll give it a shot if I have no other choice..thanks..
-vhelp 5055
TsMuxeR can make the AVCHD/BD file structure. You can then burn the AVCHD folders to a DVD with ImgBurn using "UDF 2.0". It won't create a menu, however..........
As for the menus in MultiAVCHD, I create and encode my own and use them in place of the ones MultiAVCHD create. You're only limited to the tittle placement. I won't explain how it's done, but you can figure it out if you're crafty.There is no such thing as "Idiot-Proof".........a good Idiot will get around that every time.
Why can't you tell me how it's done? I'm not that crafty but I would be really interested. Is it easy?
A DVDRip.Xvid.AC3 won't play in Bluray player
By David Banner in forum Newbie / General discussionsReplies: 6Last Post: 10th Nov 2011, 13:48 -
Which Bluray players can play AVCHD files from an USB hard
By TonyNH in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th Jun 2011, 12:51 -
used Multi-AVCHD, discs won't play in the Insignia WBRDVD player- WHY?
By Sinatrafan in forum Authoring (Blu-ray)Replies: 25Last Post: 19th Apr 2010, 07:23 -
The correct format for a movie to play on a Bluray player.
By hardhatmac in forum Authoring (Blu-ray)Replies: 6Last Post: 2nd Mar 2010, 17:53 -
Burning AVCHD for playback in Bluray Player PLEASE HELP...GOING MAD!!
By nexus6634 in forum Authoring (Blu-ray)Replies: 4Last Post: 13th Feb 2009, 13:44
