Hi, have recently acquired a LG RH177. The drive has died.
Anyways, I was wondering on whether you could remove the HDD from the recorder and plug it into the PC (To transfer xvids/dvds from pc to hdd)
I have looked at the HDD, and its just a standard 80gb ATA/IDE.
So whats stopping me from doing this?![]()
You could try it to see if any files are recognized, but most recorders use a file format that is not compatible with a PC. If it is not recognized, do not allow the PC to format it because everything will be lost. There may be a third party program that can access the files through the PC.
If you do not care about what is on the drive, then let the PC format it so you can use it as an extra drive. Do not forget to set the jumper to the proper position."I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
(NO MAN IS JUST A NUMBER)
be seeing you ( RIP Patrick McGoohan )
Yes - Might be worth a try.
So if I remove the HDD and format it on my PC, will I still be able to use it in the Recorder? Ie, are there any special files/directories for the HDD to work with the recorder?? Or does it just work off a blank (formatted) HDD?
(PS, when I mentioned drive above, I meant the CD-Reader has gone, hence why I want to transfer movies to the HDD from pc, and then re-fit the HDD back into the recorder and watch away !!)
Cheers
Once you format it in the PC, you probably will not be able to reuse it in the recorder - any proprietary formatting and files that the recorder needs will be GONE.
connecting external HDD to DVD player
By mohit in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th Feb 2009, 17:44 -
HDD Files transfer without PC
By balebob in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 19th Feb 2008, 12:59 -
HDD transfer/copy ?
By popgun in forum DVD & Blu-ray RecordersReplies: 4Last Post: 30th Sep 2007, 14:40 -
Connecting DVD/HDD LG RH7500 to coaxial loop (RF problem)
By basisboy in forum DVD & Blu-ray RecordersReplies: 0Last Post: 20th Mar 2006, 05:23 -
Possible to transfer files from win98 - xp with external hdd
By Denvers Dawgs in forum ComputerReplies: 8Last Post: 29th Apr 2005, 16:27
Statistics
Newest guides
Latest tool updates
New media comments
