VideoHelp.com Forum
  1. Member Ogilvy's Avatar
    Hi
    I need some help with choice of printer for direct print to CD's (pref. inkjet) for Ubuntu. Ive heard that Canon isn't well supported so I'm looking for something in equivalent price-range /quality as the ip4600 Canon with manageable software/driver support. Can anybody help me out here please?
    __________________
  2. Member gadgetguy's Avatar
    The HP Photosmart D5160 has Linux drivers available. I'm not a Linux user so I can't vouch for it's functionality under Ubuntu, it works great under Win2k.
    Buy My Books
  3. Get Slack disturbed1's Avatar
    I'm in the US, so model names might be different.
    The Epson R2** series works just fine with Linux, and The Gimp. The default printer drivers support CD/DVD printing, and is easily done inside the Gimp. The hardest part will be finding and using a template that lines up well. It does take some fiddling. Once you get the dimmensions, try to buy the same discs everytime.
    Google has tons of results for CD templates. Post back if you can't find one, and I'll see if I can dig up my old xcf template. Considering the cost of Ink, and issues I had with generic carts and Epson printers, I either Light Scribe, or use a stand alone Casio title printer now.
    Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
  4. Member Ogilvy's Avatar
    Currently looking at the Epson RP280..it now appears that Canon are supplying driver software for ip4600....
    http://software.canon-europe.com/products/0010649.asp
    although user reactions are mixed within Linux community. Obliged
  5. Get Slack disturbed1's Avatar
    Good luck with your new printer. I discovered this thread, should be helpful. I tried out the Verbatim hub printable PSD with Gimp and my Epson R200. Worked like a charm
    http://forum.videohelp.com/topic253367.html
  1. Printing to CD/DVD
    By folkboat in forum Media
    Last Post: 2nd Sep 2009, 23:51
  2. cd/dvd printing
    By wingfan in forum Media
    Last Post: 23rd Jun 2009, 14:52
  3. More dvd printing probs with r200
    By parman in forum Media
    Last Post: 28th Dec 2007, 16:14
  4. SLIMLINE dvd case printing
    By efiste2 in forum Authoring (DVD)
    Last Post: 8th Oct 2007, 15:27
  5. What printer to get for DVD Printing
    By faramith in forum Media
    Last Post: 27th Jul 2007, 07:41
