Hey guys, I'm pulling my hair out here trying to get this to work...
I am using an NTSC SD - STANDARD DEF Free To Air sattelite system with a PVR option. The files it creates are these .ts files, checking the manual and other utilities these files have the following specs:
Video MPEG-2 544x480 29.97 FPS 15000 kbps (h.264)
Audio MPEG 48Khz 160 kbps
What I am trying to do is get these files out of the hard drive, and onto DVD's that will play in a regular DVD player so I can play them on another TV.
I have tried various utilities with no luck...most applications will not even recognize the file or open it.
I can play the files fine on the computer using MediaPlayer classic and the Klite codec pack. I can also open them in Womble to remove commercials without re-encoding.
Tried TMPEGenc to re-encode the video...it took me 5 hours for one file, and the result was a DVD with jerky playback. No good.
I have tried ConvertX to DVD with the recommendation of some other forum (can't remember where) and it won't even read the files.
I know other people have done this, but I can't seem to find an answer as to what exactly they are doing to get this to work. I really do not want to have to 're-encode' the video files, as they are already MPEG2 files.
and just to emphasize...these are NOT high def files...all the guides and utilities are all geared towards HD but nothing I can find for SD.
HELP![]()
Buy My Books
is it mpeg2 or h264 ts files? What does mediainfo say?
MPEG-TS (No PAT/PMT): 412 MiB, 22mn 48s2 266 Kbps (15.0 Mbps), 544*480 (4/3), at 29.970 fps, MPEG Video (Version 2) (Main@Main)160 Kbps, 48.0 KHz, 2 channels, MPEG Audio (Version 1) (Layer 2)
Format : MPEG-TS
Format profile : No PAT/PMT
File size : 412 MiB
Duration : 22mn 48s
Overall bit rate : 2 526 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, Matrix : Default
Duration : 22mn 48s
Bit rate mode : Variable
Bit rate : 2 266 Kbps
Nominal bit rate : 15.0 Mbps
Width : 544 pixels
Height : 480 pixels
Display aspect ratio : 4/3
Frame rate : 29.970 fps
Colorimetry : 4:2:0
Scan type : Progressive
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.290
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Bit rate mode : Constant
Bit rate : 160 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Video delay : -64ms
I have try VideoReDo to do the convert but its not good to convert you might give it try but its not free... time limit ..
OK, I think I got it to work. After trying numerous things I think there were a few factors that were causing the issues I was seeing.
Problem 1, the file I was trying to use as a test file, may have had some missing peieces...because the source was sattelite, the signal is subject to rain fade, birds getting in the way etc, and the file had glitching in it towards the end that I did not notice...which throws the GOP structure all out of whack, and causes audio delays.
Problem 2, the file was reporting as a progressive file, that isn't the case, it's interlaced.
What I did/used to get it to work
1) Using Super video converter, drag the file to be worked on into the batch list, and use the .ts to VOB option, and in my case, choose NTSC, Recode audio and video, 29.97 FPS.
2) Once file is encoded, it leaves you a .vob file. Created a new project in TMPEG Authoringworks 4, and added it as a file. It will complain about the file, but ignore it and continue.
3) In the Clip properties, change the display mode to Interlace, and Field order to Top Field First. The rest of the settings can be left the same
4) Continue to edit, and author DVD as normal. Once written, it should be a normal looking DVD.
Hope this helps anyone who might be having the same issues.
Super is a freeware program, Tmpeg isn't (but has a trial)
I use AviDemux to convert .TS files. It can output to a variety of file formats, re-encode the streams to the format you want (no codecs are installed, it uses DLLs to encode to MP4, MP3, etc. so it won't mess with your codecs), you can use some filters (like de-interlace, sharpen, so on). It's easy to use and freeware. Highly recommended.
You don't need to re-encode the video. 15 Mbps has just a header of your DVB capture, while real bitrate of the video stream is as shown 2526 kbps. Demux TS in ProjectX or VideoReDo which may set correct information about the bitrate.
DVD-Lab Pro or DVD Maestro (after a patch) will accept the stream as it is. Your DVD player will upscale video to a standard resolution, and the result will be n-time better than any (crappy) software re-encoding.
However, you may have an issue with audio as it is in MP2 format which is non NTSC standard. I'd burn a test DVD on a DVD-RW disc and check if it plays with your equipment.
How can I Burn DVD using avi file and .srt file as subtitle
By Gayanx in forum Authoring (DVD)Replies: 6Last Post: 11th May 2012, 07:25 -
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 18:28 -
burning a dvd from an .avi file and a .wmv file
By marlo in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2010, 06:06 -
changing ifo file names on same file ext of diff dvd files
By holliquinn in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2008, 05:02 -
how can I convert dvd file on my computer to avi or a different file
By brew in forum Video ConversionReplies: 3Last Post: 19th Nov 2007, 19:21
