VideoHelp.com Forum
Results 1 to 15 of 15
    I've recently reformatted my computer and decided not to use 10 different pieces of encoding software like I used to, and just try to stick to one. I'm currently using Virtualdub 1.8.8 (I believe that's the newest stable one) and I've also been using the current official release of ffdshow tryouts, beta 6. I've come across a video that's encoded with the H264 codec. I have h264 codec enabled in the VFW configuration. I have no problem loading it, and it will play, but there will be nothing but a black screen. I know I could easily rid this problem by using SUPER, but I'd rather stick with one encoder and I'd like to do it with Virtualdub if possible.
    any ideas?
    thanks
  2. Banned
    Have you tried playing the same file in other players
    (MPC, VLC, even WMP)
    Anyway, it's not impossible that you have found an AVI without a video stream.
    Originally Posted by uglijimus
    Virtualdub... h264... nothing but a black screen
    Very common problem. Try using AviSynth's DirectShowSource().
    Does x264vfw help with reading?
    No, it's only an encoder.
    Oh, also try the DirectShow source filter in VirtualDub.
    http://forums.virtualdub.org/index.p...a214a28142a4a9
  7. Banned
    The latest versions of x264VfW are able to decode as well.
    Just checked -- you're right. Thanks for the update.
    thanks for all the responses!
    I have no problem with my KM player playing the file.
    If using Avisynth means more work than just using a plug-in or downloading and installing something, (which it looks like) I think i'll pass. Scripting looks too time consuming
    I've downloaded the x264vfw found on this site and the unofficial one from Sharktooth. Which one should I try first? I'm at work and won't be able to try it until I get home.
    I have a few of the VD plugins. I don't have the quicktime, MP4, flash video or direct show. Wonder if they would make a difference?
    i'll try these out later and let you know the result!
    What container is your source?
    The QT plugin could be the one you need. I suggest installing all of the VD plugins (except for MP4 which conflicts with QT).
    http://forums.virtualdub.org/index.p...184879c4c9047a
    Thanks for that. Getting rid of the MP4 plugin fixed problems I was having with MP4 files.
    I'm not sure about the container...I think it's an avi??
    thanks for the heads up about the QT and MP4 conflict. Very useful.
    If I can't respond within the next day (i'm moving tomorrow) I'll make sure it's some time next week.
    used the one from sharktooth and it worked!
    thank you guys!
    I got rid of all of the Virtual Dub MP2 and MP4 plugins and now it's worse than before. I don't even get it to the point of the black screen. Ii now get a red window that says "unable to initialize Quicktime qtml" What did I do, delete too much? This is really a pain.
    Is it something to do with the quicktime.ini file? What should mode be set to? I've edited it four times now
  1. Virtualdub opening H264 encoded file
    By tvbear in forum Editing
    Last Post: 26th Dec 2011, 06:22
  2. Cannot open H264 video using VirtualDub
    By kinlunyu in forum Video Conversion
    Last Post: 21st Aug 2011, 14:28
  3. VirtualDub: can no longer play H264
    By terrypin in forum Newbie / General discussions
    Last Post: 29th May 2011, 13:15
  4. help with Getting H264 into Virtualdub v1.9.9
    By dnmnbg in forum Newbie / General discussions
    Last Post: 1st Jul 2010, 17:43
  5. H264 conversion problem Virtualdub
    By Shadowofthedarkgod in forum Video Conversion
    Last Post: 5th May 2010, 11:26
