I get the error "AVI Import Filter error: (Unknown) 80040154" when trying to load an avs file. I have no idea what it means and don't know much about avs files. It's generated with GK, and doesn't include any special filters or similar, paths are correct. It worked earlier, but not after I formatted.
The avs is linked to a d2v file, made from a DVD. I have searched the internet looking for solutions, but it doesn't seem like it is caused by the same thing. I have tried reinstalling different codecs, decoders, filters, whatever. Don't really know much about the definitions and differences between those things, the point is that I have tried reinstalling them. VirtualDub is the latest version, and I'm using Windows Vista
Results 1 to 12 of 12
80040154 means in MS-speak that the program (Virtual Dub) is trying to create an instance of a filter or something similar but Windows can't create it. This is usually because a filter hasn't been registered. You need to identify the filters that are supposed to be used and then use regsvr32 <filter file> for each one to ensure the registry has all the right information.
On Vista, sometimes filters don't get installed properly when using a normal Windows installer package. This is because the package doesn't allow for Vista's user access control. Usually, though, the installation of the package will fail.John Miller -
I know this is a very old topic, but I had this problem...
I thought I had Avisynth rightly installed, so I try to "register the filters".
There is a good method : install a directshow filter package :
http://www.free-codecs.com/download/DirectShow_FilterPack.htm
there is a .bat file inside which make lots of the "regsvr32 <filter file>" (which was the first solution proposed by johnnymalaria)
but it did not change my problem.
So I re-installed Avisynth (solution by placio74) and it now works
so : thank you all -
That didn't work for me 2diablols.
I had avisynth 2.5.8 and virtual dub 1.9.10 loaded 2 .avs scripts to the job list in Vdub and the third one I get this error:
Then I changed it, installed avisynth 2.5.7 and am using virtual dub 1.8.8 loaded a new set of files and after 2 encodes in the job list boom, same error.
Method's tried already:
1. Reinstalling Avisynth 2.5.8 after the above.
2. * AVI Import Filter error: (Unknown) (80040154) - solution: A missing dll might be the problem: msvcr71.dll msvcp71.dll should be in the windows\sytem32 directory or windows\SysWOW64 (Windows 7 64Bit)
- FIXED - Is not fixed for me...from This link
3. Tried to replace FFMSindex.exe to reindex. Anyone know of other Avi Decoders/indexers?
4. Loaded a AVS script with the code: Version () loads fine and shows version. So it's not Avisynth.
Using all 32bit apps, running on windows 7 64-bits...
What do I do now?
Anyone got any ideas cause I'm at a loss... and I need vdub to work over night and can only use vdub for my current project and this isn't going to work for me with this problem.
Help
Running win7 64bit.
SOLUTION:
1.Packed All avisynth plugins into a .rar file.
2. Uninstalled everything I wanted to use.
2 1/2. I used an application called CCleaner to clean out my system.
3. Installed Virtual dub 1.9.10
4. Installed Avisynth 2.5.7
Added plugins I will be using and any additional required plugins that are needed to allow the ones I use to function. So in turn my problem was with an avisynth filter I added.
Created my index's of my files and .avs scripts then loaded each one into Vdub added filters of Vdub and added each file to Queue No problems at all !!!
Figured It out on my own and hope this helps someone in the future.Last edited by sinz; 1st Nov 2010 at 08:27.
I have a new insalation of win7 64 bit and have the same issue. version() results int he same error. I instaled koepis avisynth today, and had the error. Then I found a 64 bit instaland and installed the cmd file and copied over the files a the readme said to do, and same issue. Does nayone know whic hversion(s) etc will work?
If you want to see what I've done with my videos,
check out my video work on youtube, http://www.youtube.com/user/duhmez/ -
Just installed windows 8 and had this error. Even though I installed Klite codec pack with the avisynth box checked, it gave me this error.
I installed Avisynth as suggested and everything is running again.
THANKS!! -
Apologizes for bumping a 10 year old thread but I came across this thread when trying to fix my issues. I had been living with this error in Virtualdub for months (not being able to open .AVS files in Vdub). I simply reinstalled Avisynth 2.6 32-bit and that fixed the issue for me on a Win7 64bit machine. I already had Avisnyth 2.6 32 installed but it was obviously damaged in some minor way. Hope this helps someone.
I registered just to respond with what I found to be the error with the help of gurus developing avisynth+.
I was told to download avsmeter and do this:
I found this error:Code:To know problems in your Avisynth64 installation run: AVSMeter64 -avsinfo -log
I downloaded the visual studio redistributable package for x64 from the microsoft website and it solved this problem. For the search engines out there and other stuck users, the Virtualdub error I was getting was: AVI Import Filter error: (Unknown) (80040154)Code:C:\temp\AVSMeter3060>AVSMeter64.exe -avsinfo -log AVSMeter 3.0.6.0 (x64), (c) Groucho2004, 2012-2020 Error: Cannot load avisynth.dll Dependencies that could not be loaded: VCRUNTIME140_1.dll C:\temp\AVSMeter3060>
Using VirtualDub's "capture filter" proc amp
By sanlyn in forum Capturing and VCRReplies: 3Last Post: 31st Jan 2012, 07:13 -
HVX 200 P2 - Time Lapse "Recording Error" now file wont play or import!
By trevmarps in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 25th Apr 2010, 16:08 -
VirtualDub "format convert" audio filter - how do I use it?
By Jedi787Plus in forum AudioReplies: 0Last Post: 12th Sep 2009, 15:35 -
VirtualDub Filter for problem with "Horizontal Sync Issues"?
By lonerzzz in forum RestorationReplies: 6Last Post: 6th Apr 2009, 17:29 -
"Unknown Disc" error for all DVDs - is my player dead?
By RosieP in forum DVD & Blu-ray PlayersReplies: 6Last Post: 8th Nov 2007, 07:49
