VideoHelp.com Forum
    Hello
    I have a Pioneer DV-410V DVD player. It's set to region 2, and I want to make it region-free.
    My motherboard does not have an irda connector, and I don't have a laptop or palm.
    I found this product
    http://www.ciao.com/ST_Lab_USB_IRDA_...pter__15354426
    but I don't know whether it will work on my Windows 98SE system with its 1.1 usb port. They say it will, but I'd like to be more sure before I buy it, since I've had false promises told me before.
    But even if the product will work on my computer, I don't understand what to do once I get it. Someone posted instructions on the internet that show how to modify the firmware to make the DVD player region-free, but the instructions don't tell me how I'm supposed to modify the ini files - how do I find them on the DVD player?
    I am posting below the instructions I'm referring to. Thank you
    First you have to modify some ini files:
    1) Remove the following strings from netirsir.inf:
    %*PNP0510.DevDesc% = PNP, *PNP0510
    %*PNP0511.DevDesc% = PNP, *PNP0511
    and replace
    ExcludeFromSelect=*PNP0510,*PNP0511,*IBM0002,*IBM0 034,*IBM0020
    to
    ExcludeFromSelect=*IBM0002,*IBM0034,*IBM0020
    2) Add to msports.inf to section [Std]:
    %*PNP0510.DeviceDesc% = ComPort, *PNP0510, *PNP0511 ; Communications Port
    %*PNP0511.DeviceDesc% = ComPort, *PNP0511, *PNP0510 ; Communications Port
    to section [Strings]:
    *PNP0510.DeviceDesc = "Generic Ir Serial Port"
    *PNP0511.DeviceDesc = "Generic Ir Serial Port"
    add
    to section [ControlFlags]
    When you do this windows will recognise irda port as : Generic Ir Serial Port
    If you modified the ini files and windows didn't recognise your irda port as Generic Ir Serial Port then remove the irda port and restart your pc. Windows will now find a new hardware (Generic Ir Serial Port) and install it.
    Then type the following in a text file:
    # CUT HERE CUT HERE CUT HERE
    # Make your Pioneer DVD Player Region Free Easily
    # Region Free remote codes by KyriacosMETAL
    begin remote
    name pioneer
    flags RAW_CODES
    eps 30
    aeps 100
    ptrail 0
    repeat 0 0
    gap 35000
    begin RAW_codes
    name region
    8575 4211 576 1547 576 1547
    576 493 576 493 576 493
    576 1547 576 493 576 1547
    576 493 576 493 576 1547
    576 1547 576 1547 576 493
    576 1547 576 493 576 493
    576
    25454
    576 493 576 1547 576 493
    576 493 576 1547 576 1547
    576
    end RAW_codes
    end remote
    # END END END END END END END
    Save this text file under the name pioneer.conf
    Then download Winlirc from http://winlirc.sourceforge.net/
    Put the following settings in winlirc:
    Reciever type: RX
    Virtual Pulse: 300
    Speed: 115200
    Transmitter Settings: Unselect hardware carrier and select TX
    Config: Choose the pioneer.conf file
    When you do all these, close the settings page. Choose Pioneer remote and then click: "Send Code"
  2. Member MJA's Avatar
    Originally Posted by sasa66
    Hello
    http://www.videohelp.com/dvdhacks/pioneer-dv-410v/9461
    Thanks, but there are two firmwares listed there:
    * YJB8223B
    * YJB8507B
    Which one do I use? I live in Israel, and it's a region 2 player I bought here.
    Thank you
  1. Replies: 0
    Last Post: 30th Aug 2011, 21:04
  2. Making DVD Player region free - HELP please
    By djmark1 in forum DVD & Blu-ray Recorders
    Last Post: 29th Jul 2010, 16:31
  3. Does making a dvd player region free also allow PAL to display on NTSC?
    By dizmack in forum Newbie / General discussions
    Last Post: 25th May 2010, 19:50
  4. Making a Region 1 Player Region Free. Can't find code.
    By KitanaAsh in forum DVD & Blu-ray Players
    Last Post: 9th Feb 2010, 08:28
  5. Pioneer DV-410V-K DVD Player need to make region free
    By langer1 in forum Newbie / General discussions
    Last Post: 30th Nov 2009, 20:07
