I am using my old DVD recorder (Trutech) with a converter box to record OTA programs. Using the composite RCA connections, the quality is nothing special, but it works. I was wondering if there is any way to better integrate the ATSC tuner in the box with the recorder. I've opened up the cases, the NTSC tuner in the recorder is the same size metal box as the ATSC tuner. I realize it's probably not worth the trouble, but has any hardware hacker tried transplanting the ATSC tuner to an older DVD recorder? There would probably be firmware and power supply issues. Since the converter box only cost me $10 thanks to Uncle Sam, and the recorder is a cheapie, I'm toying with the idea once I'm ready to replace them with a newer ATSC recorder. Does anyone know anything about the small "tin box" tuners that are soldered to the circuit boards in all these devices? THey all look like the same form factor.
Though the tuner might fit, there would likely be no firmware available in the recorder to operate it or to tune the HD channels.
You're better off with your external tuner box.
You'd also probably be better off with a CECB like the Channel Master CM-7000 with S-video. I've found S-video gives me a much better picture than composite from either the same CM-7000 or something like a Zenith 901. Of course you'll have to be happy recording from only one channel unattended.
How good is the ATSC tuner in Toshiba DR570 DVD recorder ?
By SingSing in forum DVD & Blu-ray RecordersReplies: 11Last Post: 5th Apr 2010, 18:05 -
Can an ATSC tuner in an HDTV read a DVD zone 2?
By julax in forum Newbie / General discussionsReplies: 4Last Post: 23rd Jan 2009, 11:12 -
ATSC Tuner Question with DVD Player/Recorder/VHS Combo Unit
By Surfmaster in forum DVB / HDTVReplies: 4Last Post: 17th Dec 2007, 20:01 -
dvd recorder with dvd-ram, no hdd, gemstar tv guide, atsc or ntsc tuner.
By 84transam in forum DVD & Blu-ray RecordersReplies: 4Last Post: 5th Nov 2007, 19:55 -
ATSC Tuner
By ggr in forum DVB / HDTVReplies: 2Last Post: 7th Jul 2007, 23:17
Statistics
Newest guides
Latest tool updates
New media comments
