Hi. Some avi files have no sound when I play them with MPC. There's no problem with other players (WMP, VLC). MediaInfo says they are normal DivX vids with MP3 audio stream and GSpot says there are 4 compatible codecs installed. Even MPC "finds" the audio stream (audio1) but won't play the sound. What could be the problem? I've tried already to disable/enable the internal audio switcher without success. Thanks for any help.
Results 1 to 11 of 11
Check the MPEG Audio filters settings (double click on it to bring up the options dialog).
@jagabo
Yep, I got the same settings. Played around with them but to no avail. -
Under View -> Options -> Playback -> Output -- try the different DirectShow Audio settings.
Under View -> Options -> Internal Filters -> Audio Switcher -- try the different options. -
Thanks jagabo. Most of the (former mute) avi's have sound now. I checked what they all had in common and they were mostly monophonic. So I activated "Enable custom channel mapping" in Audio Switcher and the sound is working now. But I don't understand why some (stereo) avi's still have no sound in MPC while they work perfectly fine in other players?
Originally Posted by DraWing
Media Player Classic No Sound
By jrank001 in forum Software PlayingReplies: 19Last Post: 20th Jun 2014, 05:07 -
Media Player Classic .MTS no sound playback
By fitch.j in forum Software PlayingReplies: 3Last Post: 28th Aug 2011, 17:29 -
No 5.1 sound in Media Player Classic
By Dozza in forum AudioReplies: 0Last Post: 19th Mar 2010, 00:40 -
Trying to play 5.1 surround sound using Media Player Classic
By pbuscher in forum Newbie / General discussionsReplies: 1Last Post: 25th Nov 2007, 18:54 -
V-CD: Both Sound Track are played in Media player classic
By cordeliamars in forum AudioReplies: 10Last Post: 28th Aug 2007, 11:25
