VideoHelp.com Forum
Results 1 to 22 of 22
    I have been using TDK DVD+R media for many years (x16 speed, always burn at x4 speed), both movies and data backup. Never a problem. The one I used to get all the time were with grey top. I just looked a bunch of them up and see CPDR47G-CDMWP02-095 printed on inner part of it. Those always worked for me 100%. Now, with Office Depot going out of business, I picked up a few spindles, one with colored top TDK DVD+R (VR5F16-00610) and bluish top TDK DVD+R (VR5F16-00337).
    Well, all the movies burned on these new DVD+R disc skip half way into the play. Nothing wrong with my DVD player or DVD burner. I had a few original DVDR and burned the same movie which plays OK. Problem goes back to the media, those two TDK types I bought from Office Depot (they are out of business, nothing could be returned back).
    I have read here in the forum about different codes for TDK? Is there some you can recommend and where to buy them? Or should I forget all about TDK and move to another brand? I see people recommend Verbatim and Taiyo Yuden, where is the most reliable place to order these from US? How do I know these will not be a cheap outsourced kind as well? Please advice!!!!!!
    Thanks!!!!
    See www.nomorecoasters.com for a list of good media, and where to buy it.
    TDK = CMC =
    You are using low-grade media. Switch to something better.
  3. Mod Neophyte Super Moderator redwudz's Avatar
    A few places you can for look for discs online:
    http://www.rima.com/Merchant2/merchant.mvc
    http://www.supermediastore.com/
    http://www.meritline.com/cd-dvd-medi...---c-7525.aspx
    For your TDK media, check our Media page. Take the media code from your discs and plug it in there and you will get some information about it. Quite a few brands of media are made by other manufacturers and just rebranded, so quality may vary greatly.
    You can also go to this site for media info: http://www.digitalfaq.com/media/ (Or NoMoreCoasters, Thanks, LS. )
    Thanks guys! And I did just place an order with Amazon for Verbatim disk, but it sounds like a gamble to me - either I will get "good" one from Taiwan or "bad" one from India. At least I can return the "bad" one... I noticed Walmart carying these as well, but on-line order only for a much higher price plus shipping and taxes...
  5. Member Noahtuck's Avatar
    Well assuming you live in the U.S.
    Officemax has Verbatim 100 packs on sale for $24.99 at the moment.
    Originally a member since 2001, LONG LIVE TARAN's!!!
  6. Member Number Six's Avatar
    I have been using Verbatim from India, and have not had any problems whatsoever! But, even if you feel that they are BAD, they are still a thousand times better than TDK.
    "I will not be pushed, filed, stamped, indexed, briefed, debriefed, or numbered! My life is my own" - the Prisoner
    (NO MAN IS JUST A NUMBER)
    be seeing you ( RIP Patrick McGoohan )
  7. Member MOVIEGEEK's Avatar
    Office Depot went out of business?That's the first time I've heard that.
    Buying any branded media is a gamble these days but I've had good luck with Sony.
    Verbatim media is fine, regardless of where it is made (India, Taiwan or Singapore are all fine, and easily found in the USA).
  9. Member Number Six's Avatar
    I just did a search for Office Depot stores - they are still in business.
  10. Member Noahtuck's Avatar
    I missed the office depot comment... thats a new one to me also.
    There are 2 within 5 minutes of me & 2 more about a 15 minutes away
    All Office Depot in NJ are shutting down. The Wiz was 6-7 years ago. CompUSA was a few years ago. Circuit City completely shut down now. Office Depot locations shutting down too. Of couse, I'm speaking only from NJ side. Not sure if they are keeping on-line stores or if its not state-wide, but its a sad truth. The only real electronic store left in Jersey is Best Buy and they are sold out off most of the good stuff.
    Gotta check OfficeMax. I think they are still open...
    Are you sure? http://www.officemax.com/omax/catalo...tegory_Id=null listed for $60 I can't imagine a sale from $60 to $25, but will check it out, I guess...
  13. Member Noahtuck's Avatar
    Oops!!!
    My bad!!
    They were on sale last week for $24.99, they always go on sale every couple of weeks.
    sometimes even for 19.99 a 100 pack.
    I buy them there every time they are on sale.
  14. Member MOVIEGEEK's Avatar
    Their website still shows six stores in your state,if a local store closes you can always order online.
    no reason to deal with them anymore. will check local officemax.
  16. Member MysticE's Avatar
    If you have a newer burner that could be part of the problem also.
  17. DVD Ninja budz's Avatar
    Whoas! That's the first time I've heard about Office Depot going out of business!
    TDK has been outsourcing their dvd media for years now. I haven't bought them for years!
    As others have suggested just buy VERBATIM dvd media.
  18. Member gadgetguy's Avatar
    Buy My Books
    I second this. I am personally quite fond of their DataLifePlus series which are either made in Taiwan (single layer DVD) or Singapore (dual layer), but they're all good. There were some complaints only about the made in India DVD+R DL line of discs, but even Verbatim had to pull back from that and all my recent purchases of DVD+R DL discs were made in Singapore. I just bought whatever newegg.com had in the 8x-10x line and they've all been made in Singapore. I don't know if they even use India any more for DVD+R DL after the problems, but I've read that the 8x-10x line now is only made in Singapore and the lower speed DL discs may still be made in India (not sure about that).
    Can you elaborate more on this? I do use my 1 year old HP PC (HP DVD burner) to burn these DVDs. Are you suggesting I should use a slower speed? I have burned close to a few dozen DVDs on my original TDK 16x DVD+R at x4 speed, and never had an issue. Only these new kinds gave me a problem where movies play fine for half of the duration and than second half start freezing/pausing which gets more frequent after 1 hour of play time. BTW, I use the latest DVD Flick w/ImgBurn, and my DVD player is an older 5-disk changer from Sony.
  21. Member classfour's Avatar
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
  22. Member MOVIEGEEK's Avatar
    twister6,
    Go to HP's website and see if there's an update for your writer.Also try burning at 8-12x,sometimes the firmware gives a better write strategy at those speeds.Lastly run those DVD's on Nero CD-DVDSpeed to see how bad the errors are,if the score is over 90(low errors) then the problem might be the player.
  1. Quality TDK Media?
    By hech54 in forum Media
    Last Post: 24th Jan 2010, 19:42
  2. TDK now Imation - updated 10-30
    By BiggerJim in forum Media
    Last Post: 29th Oct 2008, 16:21
  3. TDK DVD+RW format before use
    By nobbydadog in forum Media
    Last Post: 30th Apr 2008, 08:55
  4. TDK Professional DVD-R media ID?
    By lordsmurf in forum Media
    Last Post: 15th Dec 2007, 11:08
  5. What should I do with these TDK's
    By Waltj in forum Media
    Last Post: 2nd Jun 2007, 23:27
