VideoHelp.com Forum
Results 1 to 16 of 16
    How to add a second audi track in ripbot??
    the new changelog says: 3 audio tracks are now possible.
    i can only use one (source: m2ts).
    picture:
  2. Mod Neophyte Super Moderator redwudz's Avatar
    You 'might' be able to use tsMuxeR to add both audio tracks to the video file. Haven't tried that, though.
    Someone else here may have a better method.
    And welcome to our forums.
    ok maybe that works, but i want to lock filesize DD9. think i have to calc my audiosize before.
  4. Mod Neophyte Super Moderator redwudz's Avatar
    If you rip a BD to your hard drive, then use tsMuxeR to do the muxing from that, you can then add that file to RipBot and process like normal with a locked filesize. But you should check that you are getting the correct .m2ts file(s) and the correct audio tracks.
    The changelog says 3 channel audio, not 3 audio tracks
    okay i overread that. thx
    i can mux another audio track inside the mkv but how to get the right audio delay from bd?
  7. Member GeeForce11's Avatar
    You can extract as many audio tracks as you want and are available from the m2ts like this example: "eac3to movie.m2ts 2: audio.ac3 -640" and just mux them to the mkv video.
    yes i know, thx.
    but what about the audio delay?
    will the video and audio file be synchron (exactly) ??
  9. Member GeeForce11's Avatar
    eac3to removes any audio delays/overlaps it finds in the m2ts, therefore the final video should be in sync with all the audio track(s) if the video was converted correctly.
    ah great.
    thanks for helping.
    do you have a gui version for eac3to - one with only few functions?
    There is a gui for eac3to it is included in the folder if you download it from videohelp, but it's not officially supported. It has most of the functions , but is missing a few, and there is no capacity to edit the command line unfortunately
  12. Member GeeForce11's Avatar
    I just made a "run.bat" file with notepad, I write everything I need in there and just drop it in the command prompt window. Once it's made all I have to change is the name of the file and the stream # if needed. An example:
    "G:\eac3to\eac3to.exe G:\BD_FOLDER\BDMV\STREAM\00000.m2ts 2: G:\BD_FOLDER\BDMV\STREAM\00000.ac3 -640"
    "G:\eac3to\eac3to.exe G:\BD_FOLDER\BDMV\STREAM\00000.m2ts" gives the detailed list of all the available streams in the file.
    okay thank you geeforce and poson.
    ill use the command line, no problem.
    can i extract original chapters too with ea3to ?
    extracting audio works fine.
  15. I'm a MEGA Super Moderator Baldrick's Avatar
    Yep, http://forum.videohelp.com/topic364227.html#1940236
    ah thx!!
  1. Ripbot audio problem
    By neto691 in forum Editing
    Last Post: 4th Oct 2011, 18:53
  2. Ripbot's Audio profiles
    By thezanny in forum Video Conversion
    Last Post: 18th Mar 2011, 20:51
  3. Ripbot Audio Level
    By wulf109 in forum Blu-ray Ripping
    Last Post: 20th Nov 2010, 13:03
  4. Video with L/R tracks to DVD with 2 channel audio tracks
    By Downloader in forum Authoring (DVD)
    Last Post: 22nd Aug 2010, 01:56
  5. RipBot audio can't be encoded??
    By crankharder in forum Blu-ray Ripping
    Last Post: 13th May 2010, 14:56
