VideoHelp.com Forum
    I have a couple of avi files with audio that only plays on the right or left speakers. How do I fix them so that the audio plays on both the right and left side? The audio format is mp3.
  2. Mod Neophyte Super Moderator redwudz's Avatar
    You could try the freeware audio editor Audacity. Add the Lame MP3 codec if you don't already have it installed. Then duplicate the mono channel in Audacity to a second channel and output as MP3 again. You can demux the audio from the original file with VirtualDub, then add back in the new two channel audio. Leave VD open while you process the audio, then it's easier to add it back in.
    Use Direct Stream copy for muxing the audio and video back together when you finish. Only takes a short time.
    And welcome to our forums.
    Just what I was looking for.
    Thank you
  1. re: A little 'balance', please.
    By StewieTeabag in forum Restoration
    Last Post: 25th Nov 2010, 12:56
  2. white balance-sample
    By kzeko in forum Restoration
    Last Post: 22nd Oct 2009, 19:06
  3. DVD5 audio/video bitrate balance question
    By Brent.M in forum Video Conversion
    Last Post: 26th May 2009, 11:38
  4. Finding the balance (x264)
    By doggyjumper in forum Video Conversion
    Last Post: 8th Dec 2008, 12:04
  5. How to balance the sound level?
    By coody in forum Audio
    Last Post: 30th Jun 2008, 21:18
