I'm having some issues with getting my new Blu-ray drive to work on my PC. The actual drive works fine, it's getting PowerDVD to play a blu-ray disc. It will play the disc for about 2 or 3 seconds, I can hear sound, see a picture but then a window pops up saying it can't initialize HDCP. Now I am fully aware of what this is and why it says this, I'm playing it from my PC to my HDTV via a DVI to HDMI cable. And the sound connected through the optical out on my PC to my optical in on my receiver. This works perfectly playing DVDs and I've been quite happy with the quality of the picture and sound. But I decided to try Blu-ray and see what happens. It seems there's no way to get past the HDCP with PowerDVD. What I'm wondering is if there's a hack or a program that tricks it into thinking it's there or something like that. I used to use a program called DVD Region Free which would trick PowerDVD into thinking that a disc was an any region disc thus allowing me to play DVDs from all over the world no matter the region. All I want is to play Blu-rays without having to purchase a stand-alone player for $300 (or however much they are now). I've been using my PC as my player for a while now and it's always worked great.
I also am aware that if I buy another video card that is HDCP compliant then it might solve my problem with this but I would like to avoid that since I know that this just has to be possible. I mean if I can hear and see the movie for a few seconds before it realizes about the HDCP then surely there's a way to trick into thinking everything is a-ok...right?
Any help would be greatly appreciated!
--Will
Thread: HDCP troubles...
$90 a year? I think I'd rather buy a new vid card. I hope someone else can come up with another, more reasonably priced, program. Thanks for the reply, jagabo.
--Will
Make sure you HDTV is HDCP compliant too.
In the future, there may be some freeware alternatives that will do the job, but currently at the moment as it stands, only AnyDVD HD accomplishes this task. Blu-Ray is still pretty much in its infancy IMO.
Obviously, the other option as you mentioned is to ensure all your hardware/software is HDCP compliant which includes, software player, graphics card drivers, graphics card and display.
Can you post a simple 'Handholding' guide to show exactly how to use DumpHD
I downloaded the latest version and noticed that within the download there are lots of other zip files - are all these needed to get DumpHD to work.
Many thanks. eon
AnyDVD HD is worth every penny
ocgw
peaceAthlon II Propus 630 @ 3.62Ghz / 8GB DDR2 1066 5-7-7-20 / 8x BD-RW / 19TB Storage
http://forum.videohelp.com/topic368691.html
HDCP strippers
By Michielvsb in forum CapturingReplies: 121Last Post: 28th Jan 2012, 00:50 -
WD TV is HDCP compliant?
By Supremo316 in forum Media Center PC / MediaCentersReplies: 1Last Post: 20th Nov 2009, 19:29 -
HDCP
By Baldrick in forum GlossaryReplies: 0Last Post: 29th Jan 2009, 07:27 -
HDCP the way forward.
By NICEBUD in forum Newbie / General discussionsReplies: 5Last Post: 23rd Sep 2008, 16:36 -
HD HTPC and hdcp ?
By bluraid in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 02:52
