http://img24.imageshack.us/img24/4761/dvdmoviefile.png
This is what's in the VIDEO_TS folder (there isn't another folder)
How do I get these files to play on my computer? I tried VLC, which normally works for everything, but no beans.
I can't convert it either (my computer overheats, even at low converting levels)
Thanks for helping out a youngin'
I really appreciate it.
Open the IFO files in VLC (in your system they are currently marked DVD Movie Info). Or try Media Player Classic. Same gig - open the IFO files, not the VOB files. If they still don't play then you have either ripped them incorrectly, or your system is screwed.
If your CPU is overheating then you should open the case and clean out the dust. You can also leave the case open, aim a small desk fan directly into the guts, and leave it running while encoding.
Open VLC by itself. Then from the drop down menu open "File"--->"Open Directory" and navigate to the directory where your VIDEO_TS folder is stored.Originally Posted by Thom Yorke
This wasn't necessary with older versions of VLC.
um im pretty new to but i find that if u want just right click on the file VTS_01_1 and go to open with and choose windows media player i find that works perfectly if u just want to play the file or get imgburn and use option write files/folders to disc and put it on a dvd and then stick it in anything u want that plays dvds takes 15 minutes max with the oldest slowest burner u could ever have
Noob question about converting ripped files to AVI
By gingerman74 in forum Video ConversionReplies: 4Last Post: 20th Mar 2010, 23:39 -
Real nOOb, VirtualDub-1.9.7
By LarryLaser in forum Newbie / General discussionsReplies: 1Last Post: 6th Nov 2009, 20:34 -
Noob Question: What subtitle files do I choose/use for DVD player
By peggypwr1 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Mar 2009, 16:24 -
Noob DVD Rebuilder Question
By peggypwr1 in forum Newbie / General discussionsReplies: 3Last Post: 10th Dec 2008, 07:33 -
Noob question about creating SRT files from an AVI
By Seroster in forum Authoring (DVD)Replies: 2Last Post: 30th Aug 2007, 14:03
Statistics
Newest guides
Latest tool updates
New media comments
