Does anyone on here use Corel (Ulead) VideoStudio Pro X2?
I would like to find out how to make my own effects, title, overlays, etc for it.
Results 1 to 9 of 9
Thread: Corel VideoStudio Pro X2 effects
I have it but have yet to fully play with it. Try Youtube; search for video studio tutorial. That turned up a number of hits, some may be for earlier versions though.
Brainiac
I searched all over and sadly found nothing....
Really ? I put VideoStudio Pro Tutorials into Google and got pages and pages. Top of the list was Corel's online tutorials, including how to do animated titles and scrolling text.Originally Posted by fayt
Yeah tutorials for things, but not how to actually make them. You can type text in and choose a title effect. But how do you make a custom title effect? like..... show text and a lit wick on it like a fuse, then it reaches the end and the text explodes in a cool effect.
For effects like rain, you can add rain to your videos, but what if I want to make snow? I need to know how to import custom stuff.
You need to get a proper compositing package like After Effects or Combustion, then spend a lot of time learning how to use it.
Then import it into corel? or do you mean corel won't let you make your own?
He means that Corel is a video editor, not a compositing package like After Effects and Combustion. If I want to do fancy effects like you describe, I have After Effects and Partile Illusion to handle the job. There is a STEEP learning curve with After Effects, and you may need the help of additional plugins, depending on the job. Not to mention that After Effects is expensive and Particle Illusion isn't cheap either.
I just did a short test in Video Studio X2. I imported an AVI file with transparency that was rendered in Particle Illusion and placed it into an overlay track. Then I dropped a video clip onto the video track. Worked fine.
Brainiac
Cool maybe in a year or so I can get the software and learn it. Thanks
Corel VideoStudio X3 Pro, Video Only Plays In Menu Preview
By pmillen in forum Newbie / General discussionsReplies: 11Last Post: 15th Dec 2010, 20:18 -
Corel VideoStudio Pro X3 and ATI TV Tuner Pro 650 Card Compatibility
By waldodiodio in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2010, 12:41 -
Anyone familiar with Corel VideoStudio Pro X2?
By brassplyer in forum EditingReplies: 5Last Post: 23rd May 2010, 10:00 -
Opinions on Corel VideoStudio X2 Pro
By Smack2k in forum CapturingReplies: 4Last Post: 11th Jul 2009, 23:32 -
Is Corel VideoStudio Pro X2 really worse than Vegas Movie Studio 9 ?!?
By vantechmag in forum EditingReplies: 2Last Post: 11th May 2009, 12:03
