Greetings ....
A few basic questions about over-the-air (OTA/ATSC) digital TV channels, and if you please, basic answers will suffice.
Q1 - I understand that a 19,390,000-bps stream is the "meat" of the 6-mhz digital channel. How much of the 6-mhz space is taken up by the data stream?
Q2 - What occupies the space NOT taken up by the data stream? Does it have a specific purpose?
Q3 - UHF digital channels 14 thru 51 can transmit at a maximum ERP of 1,000-KW (or, 1 megawatt) up to 365-meters (1,197.50+ feet) above the ground. For each meter above the mark of 365, the ERP is reduced. If this sliding power reduction scale was not employed, or in other words, if 1,000-kw ERP was allowed beyond 365 meters, what would happen? Show examples in terms of miles away from transmitter.
Q4 - In other countries, there are TV channels that are 7-mhz and 8-mhz in width. This would change how many bits per second the data stream can be. What would be the stream rates for 7-mhz? 8-mhz?
Q5 - If you have 7-mhz and 8-mhz channels, does that have an effect how much ERP you need to transmit such channels? If so, what would the maximum ERP be for a 7-mhz/8-mhz UHF digital channel?
Q6 - Suppose that instead of a 6-mhz digital TV channel, with 1 HDTV and 2 or 3 SDTV sub-channels, we had TV channels only 3 or 4 mhz wide, transmitting one EDTV (Enhanced Definition, 480p) program. What would be the maximum bits per second you could stream through each such channel (3-mhz, 4-mhz)?
Q7 - What would be the max ERP for a UHF digital channel at 3-mhz? 4-mhz?
Thanx-A-Lot, Frank-0-Video
Results 1 to 1 of 1
Digital to analog channels
By ady57590 in forum Video ConversionReplies: 2Last Post: 8th Nov 2011, 07:19 -
Getting free American HDTV Channels OTA
By the_importer in forum DVB / HDTVReplies: 11Last Post: 3rd Sep 2011, 19:25 -
Streaming Digital TV channels ?
By stefki in forum Video StreamingReplies: 6Last Post: 14th Oct 2009, 11:28 -
monitor OTA PAL mux to report channels bitrates on the fly ?
By halsboss in forum DVB / HDTVReplies: 2Last Post: 6th Aug 2009, 06:59 -
Analog vs. Digital OTA
By otaota in forum DVB / HDTVReplies: 3Last Post: 4th Apr 2008, 01:07
