VideoHelp.com Forum
    Hi all, I'm new
    I'm having trouble with a conversion you may know how to help with.
    I have a DVD which I'm ripping using Handbrake. This either comes out at m4v or can choose avi, mkv or ogm.
    After I rip it I need to import it into Flash, then create a .flv with Flash for use on a website.
    Problem is, Flash doesn't like importing m4v, and I thought I'd solved it by using .avi but the video has just come out as a blank white screen...
    Any ideas? I'd rather use free software or the software I have...
    Edited: I meant m4v not mp4
    mp4 with h264 video and aac audio is supported by flash, so see if you can convert to it directly in handbrake(m4v and mp4 is usually the same). No need to convert to flv then. See some mp4 flash examples in http://forum.videohelp.com/topic355179.html
    I do need to get them to .flv for this particular website... it's a CMS module add on and it only recognises .flv unfortunately (making things a pain for me!)
    And Flash doesn't like importing mp4 (doesn't see it a a video file, it only likes things like avi and mov it seems).
    I'm currently giving http://media-convert.com/ a go, I've converted stuff with it before it just doesn't like huge files sometimes so will see if this works.
    I would then convert the dvd to avi or mov using avidemux or mpeg streamclip. Use a video codec that doesn't compress it so much like mjpeg, huffyuv, dv and wav/pcm audio.
    Or convert dvd to flv directly using avidemux or xvid4psp, but the quality may not be as good as if you use the flash professional and using h264 video.
    I tried using streamclip the other day but it kept telling me I needed to buy something from Apple to convert mp4's (I think it was mp4)
  1. Problem with MOV > FLV conversion
    By sprinke in forum ffmpegX general discussion
    Last Post: 12th Feb 2011, 21:11
  2. Replies: 0
    Last Post: 2nd Jul 2010, 06:07
  3. Trouble with MP4 and MOV formats.
    By fesmitty77 in forum ffmpegX general discussion
    Last Post: 10th Dec 2009, 14:21
  4. h264 (MP4) to XviD (AVI) Conversion Trouble
    By m93 in forum Video Conversion
    Last Post: 12th Dec 2008, 10:21
  5. Problems with conversion FLV to .mov u others.
    By djinnverde in forum ffmpegX general discussion
    Last Post: 30th Sep 2008, 10:32
