I have a Liteon 5045 which has had the DVD recorder replaced 5 times since I bought it. Yet another failure and now out of warranty. There are several hours of recordings I can play through the player itself but cannot transfer onto DVD. I've removed the hard drive and hooked it up to a desk top PC but it cannot see the drive. Liteon tech support have no solutions !! Can anyone advise how to get a desk top PC to see the drive ??
Ta,
Brian
allibg5
[Replaced the DVD drives 5 times!!!
What were they replaced with?
The format in the liteon is fat 32 and 64k clusters
The files are xxx.VOB ---[they can be changed to xxx.JPG if necessary---]
A program as Power DVD in a PC will read and play them as VOB or JPG
I use Win 98se and have no problems. A PC with an other OS might have issues depending its setup
If the unit will play the HDD
It does recognize the DVD drive but might take a min or so in a power up.
Can I assume the drive will not play any disk
It might be the DVD drive is going bad,or is dirty
LCSHG
Many thanks for your reply.
Yes. The DVD player / recorder has been changed 5 times. I obviously would not recommend Liteon !!
I tried connecting the liteon hard drive to a desk top running win xp.
The hard drive was not recognised at all.
You are right. The DVD player / recorder will not recognise discs of any description ie pre-recorded or home made. It has been cleaned and it makes no difference.
I do have power dvd so I shall try to see if a win 98 desk top recognises the hard drive and go from there.
Thanks again.
allibg5
Allibg5
If liteon replaced the drives they were most likely replaced with the original DDW units .
They did have their problems. Most have replaced the drives with PC units. A list of drives to use is given at the sites given below
The liteon units produced a very good recording
While the format is Fat 32 I would doubt that any Windows OS would recognize the HDD as it is formatted.. A sticky at the below sites coves the OS issue.
While the DVD drive will not play a disk and was cleansed, the system does recognize the drive. If it didn’t it would NOT play the HDD
Even with Power DVD I doubt the HDD would play..
The files would of you can get yhem to a PC as Files.
At this time I would not Play around with The HDD as you may lose files
While the sites given are mostly ilo, It is a liteon product and all info is relative. The inside guts are the same. The firmware governs the HDD size and all-rite feature.
http://www.techolio.com/
http://www.normediasolutions.com/portfolio/
This sire will give info on the liteon drives
http://codeguys.rpc1.org/firmwares.html
PS
A user from the UK reported that a 16H5s worked ok on all functions
Info on the liten drives and the family’s is at this site.
Liteon LVW-5045 replace DVD drive, project started...
By dainova in forum DVD & Blu-ray RecordersReplies: 18Last Post: 5th Apr 2011, 06:04 -
I have some VHS tapes that I want to transfer to a computer hard drive.
By marada in forum CapturingReplies: 15Last Post: 30th Nov 2009, 08:35 -
Sony AVCHD transfer to computer hard drive
By jal79 in forum Camcorders (DV/HDV/AVCHD)Replies: 16Last Post: 22nd Jul 2009, 14:21 -
Can I transfer my direct tv dvr movies to a hard drive?
By Vityaz in forum DVB / HDTVReplies: 11Last Post: 23rd Jun 2009, 16:54 -
How do I transfer shows recorded to hard drive to DVD?...
By Tigergreg in forum Newbie / General discussionsReplies: 10Last Post: 4th Mar 2008, 19:35
Statistics
Newest guides
Latest tool updates
New media comments
