Hey all!
My PHILIPS DVP642 died on me, the power light just keeps blinking & it doesn't turn on.
However, I want to get my disc out, is there a way to do this somehow?
Thanks!
Just start taking it apart....It's already dead.
Are you afraid of damaging it?
Unplug it first. Plug it back in see if it works.
Easy to take the disk out, just unscrew the top. After you unplug it that is.
It's not as easy as just removing the top as the drive cage doesn't allow access to the disc. I would simply try prying the drive tray open. If you can't do that, then remove the countless screws holding the top on, and then pry the drive door open. Just did this myself a few weeks ago.
Google is your Friend
FIRST, try handyguy's suggestion!!!! You wouldn't believe how many problems like yours can simply be remedied by unplugging the unit for about ten minutes, then plugging it back in and hitting Eject.
Philips DVP642 "no disc" of death: 6 month failure
By _ck_ in forum DVD & Blu-ray PlayersReplies: 59Last Post: 26th Mar 2012, 12:29 -
Remote for Philips DVP642
By Melina in forum DVD & Blu-ray PlayersReplies: 2Last Post: 10th Jun 2010, 21:54 -
DVP642 died. Do I want 3980 or 5990 for correct PAL to NTSC conversion?
By WinME in forum DVD & Blu-ray PlayersReplies: 19Last Post: 28th Apr 2009, 20:44 -
Philips DVP642 finally died...
By Krispy Kritter in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Feb 2009, 13:06 -
Philips DVP642 and DivX 6/Ultra
By cheerful in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Aug 2007, 11:43
