So I converted an AVI source file on my computer to MPEG2 using SUPER (by eRightSoft). I created an ISO image and burned it to a DVD using Nero. I played it on my PS3, ran like butter. I then played it on my Phillips DVP3980, and to my dissatisfaction, found the aspect ratio to be distorted and forced into fullscreen. So I go into the setup menu, change the TV Display option to 4:3 Letterbox, then to 16:9, only to discover no changes whatsoever.
Help?
Thread: Philips DVP3980/37 Problem
Sounds like the AR flag isn't set correctly. I don't know if that would be a problem with Super or Nero. You could try conversion/burning process again using a different app. ConvertXtoDVD works well (although not free) or you could try DVD Flick or FAVC. They will all accept the avi input file and burn a DVD.
Google is your Friend
My Unlocked Phillips dvp3980 has suddenly stopped playing AVI files?
By UmmAddan in forum Newbie / General discussionsReplies: 5Last Post: 10th Mar 2012, 11:58 -
My phillips dvp3980 Stops playing movies 3/4 of the way through.
By UmmAddan in forum Newbie / General discussionsReplies: 10Last Post: 22nd Nov 2010, 15:36 -
Help with Philips MCD119 problem
By SteveHarrison1 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Sep 2010, 16:07 -
Problem with Philips DVDR-3505
By obolon84 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 12th Jul 2010, 09:54 -
Philips DVP5980 upgrade problem
By snadge in forum DVD & Blu-ray PlayersReplies: 0Last Post: 18th Feb 2009, 09:55
Statistics
Newest guides
Latest tool updates
New media comments
