I want to make sure that you can definitely record audio from something other than the HDMI port in the Blackmagic Intensity (none pro) so I could record my Xbox 360 video (only) feed through the HDMI port, then my PC audio from stereo-mix. This'll allow me to plug in my 360 audio and my microphone and record them at the same time.
Does anyone have first hand experience with the software? Or can you use the card with other programs as if it was a webcam (and being able to achieve HD resolutions)?
Also it'll save me about £40 for buying some cables to convert my VGA cable to a HDMI cable instead of buying the "pro" version :P (and shipping time is longer on the pro version for some reason: http://store.apple.com/uk/product/TP...mco=MjIzODEzNA).
