VideoHelp.com Forum
    My remote is starting to get touchy. Can anyone recommend a universal that works or does anyone know the remote code? A friend of mine also has a unit and he lost his player in a cross country move.
    Any help would be greatly appreciated.
  2. Member Krispy Kritter's Avatar
    The actual remote code will vary by manufacturer. Assuming you have a universal remote, you will need to contact the manufacturer of the remote and see if your player is supported...and if it is, the code.
    Google is your Friend
    Maybe someone here has had the same problem, and has bought a universal remote that works?
    Any assistance would be great!
  4. Member Krispy Kritter's Avatar
    Any of the Logitech models would likely suit you just fine, I've used a few and they work quite well and have support for all the hardware I've tried to use. Any of the "All-In-One" remotes will likely also work. But if I had to choose, it would be a Logitech.
    Thanks! I'll give one a go.
  1. Remote code for Memorex MVD2016 needed
    By ravenswd in forum Newbie / General discussions
    Last Post: 23rd Feb 2011, 16:47
  2. Where to find universal remote code for Philips DVP5990/37?
    By FredThompson in forum DVD & Blu-ray Players
    Last Post: 6th Mar 2009, 10:14
  3. Replies: 4
    Last Post: 8th Jan 2009, 01:57
  4. VLC Player - Code Needed For Remote
    By John_Jordan in forum Programming
    Last Post: 15th Jan 2008, 21:13
  5. DV-DS81E hitachi DVD recorder universal remote code needed
    By Dekaspace in forum DVD & Blu-ray Recorders
    Last Post: 14th Jul 2007, 11:28
