When my laptop crashed a few weeks ago, I had an Adobe Premiere Pro project that I had not finished. I was using Adobe Premiere Pro 1.5.
I did not know whether Premiere Pro 1.5 project would open in CS4 and even if it did, would the files be affected in anyways?
Also, I had a digital voice recorder that I used to record my professor's lectures. Sony told me that it would not work with Vista.
So I went through all the research to downgrade from Windows Vista to XP. I even purchased the Windows XP Home SP2 retail CD.
However, I connected the voice recorder to the computer and it worked with Vista.
Then I downloaded a trial of Premiere Pro CS4 and I was able to open my Premiere Pro 1.5 project in Premiere Pro CS4.
So with these compatibility issues solved, I don't know if it would be worth the hassel to try to downgrade to XP.
I may sell my new Windows XP CD.
I can get an academic version of Premiere Pro CS4 for $350. Anyone know if there are any limitations to an academic version other than not being able to use it for commercial purpose? I will mainlly use it to edit videos to post on YouTube. But may also make videos for my family. I will not be using it for academic purposes. Windows Movie Maker is too simple for me.
Should I get CS4 and stick with Vista or should downgrade to XP and stick with Premiere Pro 1.5?
Also, in CS4, I no longer see the DV-AVI option when exporting.
Results 1 to 1 of 1
Exporting Premiere Pro CS4 Project - Adobe Media Encoder question
By schmickers in forum Authoring (Blu-ray)Replies: 1Last Post: 27th Jan 2012, 18:51 -
Adobe Premiere Pro CS4 Cannot Import .mp4 File
By spike32 in forum EditingReplies: 5Last Post: 19th Jan 2010, 08:15 -
Vegas Pro 9 versus Adobe Premiere CS4 ?
By Chrushev in forum EditingReplies: 1Last Post: 23rd Oct 2009, 18:23 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 09:00 -
Adobe Premiere Pro 1.5 files comptible with CS3/CS4?
By vid83 in forum Newbie / General discussionsReplies: 6Last Post: 22nd Feb 2009, 14:15
