Hi all:
Please note that I know nothing about blue ray and HD.
I have got a movie file with almost 8 GB in a format called 1080p.blue rayx264-HD1080.
Now can someone please tell me what to do to get the most out of it ??
I think I would need adequated tools to do that , bur please can someone give some ideas ??
tks in advance.
Thread: what to do with my HD1080 file
What are you trying to do with it ?
How and on what are you going to watch it ?
Do you have a HD TV ?
If so, do you have your PC connected to it ?
If you don't have a Blu-ray player, PS3, Xbox360 or HDTV, then you have just wasted 8GB of download, as you will have to convert the file to standard DVD format to watch it, and will lose any and all advantages of the 1080p format.
Yr questions answered to my question.
Thank you very much guns1linger.
It's not Blu-Ray, it was just ripped from a Blu-Ray source. If it was compatible with a Blu-Ray disc player it would be tagged as AVCHD.
You could probably watch it on a PC monitor if you installed the right software and codecs but I don't think your PC hardware is quite up to it. You could also convert the file to AVCHD but it requires a bit of effort.
Get a WD TV HD Media Player or a Popcorn Hour. Then you can probably (depending on the container) watch it in HD on an HDTV.
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 18:28 -
Audio track disappeared from .TS HD1080 file. Any suggestion please.
By cyberbill in forum AudioReplies: 2Last Post: 25th Jan 2010, 05:50 -
By cyberbill in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2010, 04:34 -
changing ifo file names on same file ext of diff dvd files
By holliquinn in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2008, 05:02 -
Converting VOB file to MP4 file. Video is perfect, audio is nonexistent.
By jdfrosty in forum ffmpegX general discussionReplies: 6Last Post: 17th Jul 2007, 18:31
