VideoHelp.com Forum
  1. Member darkzero297's Avatar
    I don't get it. The only strange thing I remember was when I downloaded a video and accidentally set it to "Open With" Media Player Classic rather than "Save As". I quit the video and re-downloaded it and now all the sudden Media Player Classic won't play audio anymore.
    Nothing is muted, audio still works in all my other programs and I have shut down my computer, restarted and uninstalled CCCP 3 times and reinstalled it and it still won't play any audio. What in the world can I do to fix this?
    Do you get audio playing that video with other players? e.g. KMplayer, VLC?
    What does mediainfo say about that video?
    Can you get audio from MPC playing other videos?
  3. Member darkzero297's Avatar
    No, Zoom Player and other players still have audio. The only thing affected is Media Player Classic. Everything else is fine. I'm really use to MPC and I'd greatly prefer to keep using it.
    BTW, it is all videos that are affected, not just the one that I downloaded. No videos have sound in MPC.
    Check your audio configuration in MPC (audio=>options)
    When you install CCCP or other codec packs (not recommended btw), I think they use MPC-HC as default, not MPC, so you may have to play with the configuration..., did you do a custom install?
  5. Member darkzero297's Avatar
    I went to Audio Options and it took me to an audio switcher thing. There isn't really anything here. Just a few small options and some graph thing. I'm using MPC-HC BTW. I don't really know what to do. My audio options should be the same in both Zoom and MPC, I don't know what to do here. I did recently install Realmedia codecs in addition to MPC, I never had any problems though. Should I take that out?
  6. Member darkzero297's Avatar
    Ok, it seems to be working now. I don't know what happened. I tried to install Media Player Classic and CCCP separately and that finally worked. I guess all is well now...
  1. Playing flac. files using ffdshow and Media Player Classic
    By Cunhambebe in forum Newbie / General discussions
    Last Post: 5th Jul 2011, 04:32
  2. Playing subtitles off VOB file in Media Player Classic
    By aduh11 in forum Newbie / General discussions
    Last Post: 27th Dec 2009, 14:44
  3. Problem playing a .mov file with Media Player Classic - No audio
    By shiningwizard in forum Software Playing
    Last Post: 20th Sep 2008, 06:52
  4. Replies: 4
    Last Post: 1st Aug 2008, 22:49
  5. Windows Media Player no longer playing 16:9 video correclty
    By eon_designs in forum Software Playing
    Last Post: 1st Oct 2007, 12:05
