I have Audacity 1.3.7 (betta). I cannot export a file to mp3, it tells me that the "Lame" version is not compatible.
Any suggestions?
Thread: Export Audacity to mp3 on a PC
do you have Lame installed? I believe that it uses Lame for encoding MP3s.
http://www.rarewares.org/mp3-lame-bundle.php
Thank you.
I have it installed and it is not working together.
Did you use the lame_enc.dll file?
Once you move the .dll file to the Audacity folder then go to Preferences>File Formats and then click Find Library.
Thanks.
It still doesn't work. It tells me that I'm linking the lame_enc.dll version 3.98, which is not campatible with Audacity 1.3.7, please download the latest version of Lame. I cannot find any version of Lame older thab 3.98.
From the changelog:
Instructions specific to audacity:Note: Windows users wanting to export MP3 files will require the latest version of the LAME encoder from http://lame.buanzo.com.ar/
http://audacityteam.org/wiki/index.p...s_Instructions
Thank you changelog!
I finally got it to work with your help.
How to export Lame MP3 to custom bitrate?
By Artas1984 in forum AudioReplies: 6Last Post: 17th Sep 2011, 14:29 -
Can I batch process some mp3's with Audacity to make them louder?
By snafubaby in forum AudioReplies: 2Last Post: 10th May 2011, 13:24 -
Creating .mp3 ringtones using Audacity
By Hittz in forum User guidesReplies: 11Last Post: 17th Aug 2010, 16:11 -
Question about using Audacity to join mp3 files
By jimdagys in forum AudioReplies: 2Last Post: 25th Dec 2008, 07:21 -
audacity and mp3's?
By tchambers in forum AudioReplies: 9Last Post: 6th Dec 2008, 20:21
