I've just started backing up some of my VHS-C tapes to DVD. Some of the tapes go back to 1998. I have successfully transferred 26 tapes using my setup with no issues, till now. My setup is a VHS-C adapter into a Sanyo VCR/DVD player with S-Video out to Sony HC85 and then into my computer.
I'm trying to transfer and the video goes blank (blue) but the audio plays fine. When I "search" fast forward or rewind the tape I can see the video fine. When I try and play those areas they are blank again. I've cleaned the read head and it doesn't seem to make a difference. I could understand if I couldn't see the video when I search or played normally. But why can I see the video in FF and RW search?
Hopefully someone else has seen this and knows what I'm talking about.
EDIT:
This discusses a similar problem, with the exception that it is not the entire tape, but only certain sections.
http://www.videohelp.com/forum/archi...e-t359779.html
Thread: Can't view video on VHS-C
Upon further investigating, with a different VCR, I found that it's not a prob with the VCR. I watched the same areas that would be "blued" out with just the VCR hooked up to a TV. The video jumps around in those sections. But somehow the area that jumps around is not coming out of my HC85. The HC85 just "blues" those areas out.
If I can't fix the tape, I would rather see the bad sections than just a blue screen.
Your problem is probably still the VCR. Sometimes older tapes need special restoration. I deal with this daily, from customers. Lots of bad tapes out there.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
I've decided it's most likely the tape. Thankfully, the portion that has a problem is of no real memory making. I remedied some of the problem by putting the VHS-C onto VHS, and then to the computer. I'm just glad the section with my lil girl coming home from the hospital didn't have a problem.
I might check into special restoration when I get a chance.
how to view old 3/4" video
By newsshari in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2011, 13:47 -
Video MetaData - How do i view this?
By jmadden93 in forum Video ConversionReplies: 1Last Post: 12th Jun 2010, 13:49 -
Video Partial View
By wonstep in forum Software PlayingReplies: 8Last Post: 29th Apr 2009, 22:04 -
Sansa View 8 GB Model how do I convert video for use with the sansa view?
By goheadtry in forum Video ConversionReplies: 1Last Post: 2nd Jun 2008, 00:01 -
Cant view PAL VHS tape. What are my options?
By quantass in forum Video ConversionReplies: 3Last Post: 15th Apr 2008, 10:02
Statistics
Newest guides
Latest tool updates
New media comments
