    Long time reader, first time poster
    I have a Mitsubishi WS-55315 RPTV (1080i native) using a HDMI->DVI cable. I've been using 1080i on a Philips DVP3960 for the last year with no problem with either DVD-Video or DivX .avi files. I upgraded to the DVP5990 (v31 firmware) so I can have USB instead of burning DVD-RW all the time. When I set the HDMI to AUTO or 1080i it goes into Auto-Recovery mode and switches back to 480P. I can only have 1080i if I start the movie and then switch to 1080i while watching. When I turn it off/on, it goes back to 480P. I've done some internet searching and it seems I'm not alone but I want to confirm this will be a problem before I just give up. You guys are the experts. :>)
    Thank you in advance!
    Mine does exactly the same thing. My 5960 once set to 1080i stayed there
    but, the 5990 evidently will not. What I noticed was that if I had my TV on
    and set to receive an HDMI signal, the 5990, when turned on, would play at 1080
    so it does save the setting. Evidently it looks for something from the TV
    and if it doesn't get it just switches to 480p
    I have not upgraded to the firmware that is posted on this site yet because I just purchased the unit.
    Maybe that will cure the problem.
    I really like the unit, so even with this problem, I'm keeping it.
    Tony
  1. Replies: 4
    Last Post: 22nd Oct 2007, 20:00
  2. Solved my 1080i -> 480p w/Pulldown Issues!
    By CubDukat in forum Video Conversion
    Last Post: 30th Sep 2006, 11:05
  3. 1080i HDTV to 480p DVD w/Pulldown: Round Two
    Last Post: 17th Sep 2006, 13:38
  4. 1080i HDTV broadcast to 480p DVD-R?
    By Robert Simandl in forum DVB / HDTV
    Last Post: 18th Feb 2006, 21:43
  5. Is it possible to convert component to dvi? (480p to 1080i)
    By ronjon228 in forum DVD & Blu-ray Players
    Last Post: 26th Sep 2004, 04:53
About   Advertise   Forum   RSS Feeds   Statistics   Tools
