hi guys, i have the raw footage of a video on my computer in the form of pictures, which i use avisynth's imagesource to pull into the video in a numerical sequence based on the filenames... the problem is that some of the frames are bad and i had to delete them, so there are gaps in the numbering... when i play the avs script, the missing frames are shown as all black, and when i encode it with virtualdub with the 'preserve empty frames' option off, the black frames are still there
is there a way to have anything other than black frames fill in for the missing frames? or is this an imagesource problem?
Results 1 to 12 of 12
Thread: missing frames
you can re-number the images so they are sequential
that would result in a skip in the video, where everything suddenly jumps when the blank frames originally happened
Replace the missing frames with nearby frames.
you can insert a duplicate (before or after frame) , but then you will get a studder /lag
EDIT: Technically you didn't beat me jagabo, same post time!
that would be a more preferable solution
is it possible to fade between 2 pictures across a number of frames using avisynth? or do i have to make the frames manually with an image editing program or something...
on a slightly related note, is there any such thing as a program that scans for numerical filenames and reports any breaks in the sequence, as unlikely as it might sound... i cant remember what numbers those missing frames were
VirtualDub will stop when it hits a break.Originally Posted by carmatic
it didnt for me, tho, because i see black frames where the missing frames are... in fact they are truly black, because if i use something like deflicker, the frames immediately after the black frames are dark, like they faded in from black
Don't use the AviSynth script. Open the first image in VirtualDub. It will stop when it hits a break.
so your saying that if virtualdub detects that there is no file with the name of the current file + 1 , it will stop with some error instead of filling it in with an empty frame?
It will stop at the first missing frame. No error message. You can see how many frames have been opened so you know where the missing frame is. If you have many breaks this will be a pain because you'll have to repeat the process many times.
H.264 conversion/frames missing/skipped
By iGnight in forum Video ConversionReplies: 18Last Post: 29th Jan 2011, 02:23 -
Tivo troubles with missing frames
By Solarjetman in forum Video ConversionReplies: 3Last Post: 12th Jan 2011, 12:50 -
AVI jerky/missing frames?
By MdMa11 in forum Video ConversionReplies: 10Last Post: 25th Apr 2010, 23:13 -
Mpeg 2 for Blu-ray audio exports with missing frames at beginning and end.
By jbandy1 in forum EditingReplies: 0Last Post: 21st Jan 2009, 16:34 -
Jumpy video with animated films - like there are frames missing!
By junks in forum Authoring (DVD)Replies: 8Last Post: 10th Jan 2009, 09:27
