VideoHelp.com Forum
  1. Member mattstan's Avatar
    I'm not sure if it's ok to post this here, cos it's not video related, but its always been a helpful forum so if not ok let me know.
    I've made some compilations of FLAC music files all from different artists and intend to burn some CDs with them.
    The problem is the audio levels all differ, which is really annoying during playback, one song needs the audio turned right up then the next blares at you really loudly and you need to turn it down.
    Clearly I need to normalize the volume of all the tracks. Now this would be easy enough if dealing with one track but the minimum I've got is ten, all with varying audio aplitude levels.
    Is there any way I can normalize the whole lot to the same or similar aplitude levels? If so how and using what (preferably free) software?
    Thanks.
  2. Member t0nee1's Avatar
    You should be able to do it with foobar2k>Replaygain>scan selection as a single album or Albums(by tags)...Try it...You can always remove Replaygain info...
    The burrrn proggie, has a replaygain feature as well...
    "I typed the word Google into Google. Guess what came up? Everything."
    "What we've got here is failure to communicate"
  3. Member mattstan's Avatar
    Thanks for the info., I'll take a look.
  1. DVD normalization
    By debrock in forum Audio
    Last Post: 10th Jun 2011, 03:57
  2. BD Reduilder Audio Normalization
    By wulf109 in forum Blu-ray Ripping
    Last Post: 5th Feb 2010, 01:11
  3. Normalization by percent
    By l-w-c in forum Audio
    Last Post: 15th Oct 2009, 07:11
  4. mkv video audio normalization / post-processing audio normalization
    By o6uoq in forum Newbie / General discussions
    Last Post: 5th Aug 2009, 00:17
  5. Can't disable audio normalization?
    By ngibbs in forum ffmpegX general discussion
    Last Post: 28th Apr 2009, 16:18
